Oliver Plow Parts
FM
02-20-2007 17:04:20
Can anyone tell me if other models of oliver plows than the 4240 used the same lever parts, wheel hubs, and pull hitch?
Found one I'd like to get but its pretty rough and I'd need those parts. There are many pipe backbone plows around my area and I'm wondering if the parts would fit.
Mike
J Schwiebert
02-20-2007 17:47:56
 Re: Oliver Plow Parts in reply to FM, 02-20-2007 17:04:20
Let answer the second question first. If both plows have antifrction bearings the hub should interchange. Are you talking the 4440 or 4441 pipe plows? I have not looked in a long time as to what I all have in plow parts books. Where are you located? J.
FM
02-20-2007 20:01:13
 Re: Oliver Plow Parts in reply to J Schwiebert, 02-20-2007 17:47:56
I'm not sure about the model numbers on the pipe plows. I do know they are oliver :-) Semi mounted or pull type in 3 or 4 to 6 or 7 bottoms. I am located in Ohio.
Mike
J Schwiebert
02-21-2007 14:13:10
 Re: Oliver Plow Parts in reply to FM, 02-20-2007 20:01:13
I am in Ohio also. Whaere are you? J.
FM
02-21-2007 19:22:32
 Re: Oliver Plow Parts in reply to J Schwiebert, 02-21-2007 14:13:10
Wooster right now, I'll be moving a little North West to West Salem in the near future. You ever hear of any Plow days other than up in Perrysburg?
I got a 3 bottom 4240, and looking to add a 2 bottom to the fleet. I need some ground to plow to satisfy the itch:-)
Mike
