Oliver Raydex bottoms and 4240 Questions
FM
02-16-2007 12:00:47
List,
First question: On the Oliver 4240, I was told there were those with a big rear wheel and a small rear wheel. Were these just different options available at the same time, or was one used before the other?
Second Question: Is a Raydex share a Raydex share or are there different sizes?
Third Question: On the Raydex shares, why is there a clipped corder on the leading edge? Do these things really pull easier than the rest?
AB
02-17-2007 22:24:09
 Re: Oliver Raydex bottoms and 4240 Questions in reply to FM, 02-16-2007 12:00:47
third party image
Here is a pic of one I restored last fall. It is a late model with large rear wheel.
Bill L WI
02-16-2007 18:29:47
The 4240 had a small wheel on the early ones and went to the large wheel on the later plows.
The plow share is from 12 to 18 inch and the share, if it says Radex will have a set of letters and numbers that tell you the width of cut per bottom (ex. R14R, RR14R, or RCA4 is a 14"; R16R, RR16R, or RCA6 is a 16; etc.). You can also tell which it should have by the width between the beams. If you go to get shares, the 16" shares are usually less expensive than the 14 or 12. All you need to do is cut them off to 14 or 12 with a chop saw.
The Radex share is curved, making it easier to go into the ground etc. If you go to a farm store or another to get the shares, good luck on how it plows. The original bottom parts are available thru your local AGCO dealer and it will do a better job. We have a lot of Amish here that buy original shares because they plow so much easier.
FM
02-16-2007 20:13:48
 Re: Oliver Raydex bottoms and 4240 Questions in reply to Bill L WI, 02-16-2007 18:29:47
Bill and all,
Thanks for the information. I was looking at the manuals I have and I am almost starting to think I can just drop the third bottom off my plow to make it into a 2nd and wouldn't have to buy any parts or anything. Is that true?
Mike
evielboweviel
02-17-2007 08:13:48
 Re: Oliver Raydex bottoms and 4240 Questions in reply to FM, 02-16-2007 20:13:48
yes on a 4240 no on a 4340
Ron
Jim in polk co
02-16-2007 17:45:08
We used to have an oliver plow, it would pull easier and go in the ground better than our ih plow when the conditions were dry. Have you ever looked at one of the newer oliver/white plows? the first rolling coulter is probably mounted on the bar between the lift arms of the tractor. If you look at a john deere plow you will notice how far back the first bottom is. I was always taught that a shorter hitch pulled easier.
J Schwiebert
02-16-2007 17:32:09
I am not the plow guy. The answer to the second question is yes. There are also different bottoms. Look on the back of the moleboard for the number of the bottom. Getting back to the second question: Bottoms were made in sizes from 12 to 18 inch so the shares have different length. The nuts that hold them on are also left hand thread.
