Josh,Assuming this is a normal 8 ft bed truck and small bales. You can put 4 bales on edge just behind the cab, 3 on edge between the wheel wells, 4 on edge behind the wheel wells. Then put bales cross ways as many will go front to back and I think you can put three longways down the middle if there is not too much overhang on the sides. Next put bales longways on these. Then put bales crossways, skipping bales in middle. Then one row of bales on top to lock the load together(hopefully). Then drive SLOWLY off the field and CAREFULLY to the barn. There are variations on this and I may blessedly have forgotten some of the details. IMO bales should be made twice as long as they are wide so that stacks in barn or on trailers can be off set to lock stack together(hopefully). When throwing bales up on truck or stack you should grasp the two pieces of twine, one in each hand, and swing the bale up in a long arc underhanded. Pushing it up like shooting a basketball puts too much strain on the shoulder joints. Have fun. KEH
