JD 1209 Mower /conditioner?
Scott(MO)
02-14-2007 16:35:25
Hello, I'm looking to get a older mower/conditioner and a dealer has a JD 1209. Does anybody know anything about these? Good?Bad?...Do they have any trouble areas to look at? Is the sickle bar easy to get out of these models or not? I know when your dealing with older equipment like this , it's hard to see everything , but I just thought maybe some of you all have run them. Any help would be appreciated.
Scott
Devin Sparks
02-16-2007 05:53:24
 Re: JD 1209 Mower /conditioner? in reply to Scott(MO), 02-14-2007 16:35:25
I have a 1207 which is the same but 2 ft shorter. The sickle section is easy to remove. If you buy it do yourself a favor and buy your parts from the dealer or shoup. Dont buy the guards from TSC. The guards they sell will not work and will cause it to plugup and drag your grass down.
Coaltrain
02-15-2007 09:33:30
One of the few peices of JD equipment that I thought was a lemon was a JD 1209. The guards seem to be at a incorrect angle plugged to easy. The wabble box carrier was not reinforced well enough. The wabble box was not designed for this heavy use. Difficult to tow on county road.
george pickering
02-15-2007 05:05:27
I WOULD STICK WITH A NH STILL A LITTLE GUN SHY ON JD HAYBINES DONT HAVE ANT PROBLEM WITH THE REST OF THERE EQ JUST THE HAYBINES WOBBLE BOXES AND CRIMPER ROLLS
Tx Jim
02-15-2007 04:08:13
Check the sickle drive (wobble box) mounting bracket for cracked welds or rewelds. Also check looseness of sickle drive arm. Check crimper rolls for missing rubber as they are $$$$$$$ to replace. Tx Jim
rbct
02-14-2007 17:16:57
used a borrowed one a few years ago on my 10 acres of timothy hay in pa. pulled by a farmall 300 with no problems. worked well is a good unit. it was old with worn rollers but still worked well. expensive to buy new rollers. sure beats buying a new one for 25 grand.
