John Deere Cultivators
Scott Griffith
02-13-2007 11:40:41
Hello fella's and ladies,
I have a set of 2 row cultivators "from a John Deere B" the fella says, that I got them from. So how do I tell by looking what tractor they will fit? I have an A, B and MT John Deere I might like to mount them to.
Scott
Leroy
02-13-2007 18:06:49
 Re: John Deere Cultivators in reply to Scott Griffith, 02-13-2007 11:40:41
First off are they the the ones with the quick tatch fram or do they mount only to the frame side rails with just a rod going to the bolts in the top front of the pedistal? A B tractor has a narrower frame than the A unless you have a 34-39 A and would need different quick tatch mounts for any A than for a B and the quick tatch frame side rails are different (length) for the pressed frame tractors than the cast or angle frame tractors. Without the quick tatch both will mount directly to any of the A or B tractor side frame rails but you would need different brace rods for the front for each of the different model tractors. The MT does not have the frame side rails and I would not know how to mount a cultivator on one. Then you get to the lift and some will work on any A or B with hydrolics but a hand lift unit will not work on a hydrolic lift tractor. The MT hydrolics are entirely different and would need an entirely different lift settup. 100 ? that need answers before any one can tell you if they will fit eather tractor or not.
Scott Griffith
02-14-2007 05:09:22
 Re: John Deere Cultivators in reply to Leroy, 02-13-2007 18:06:49
Thanks for the replies. Where is the best place to get parts for these old cultivators? The only thing I am missing thus far is the handles to adjust them on both sides. I have everything else to my knowledge.
Scott
Leroy
02-14-2007 11:29:05
 Re: John Deere Cultivators in reply to Scott Griffith, 02-14-2007 05:09:22
On some tractors you do not need the adjustment levers, if only power lift you need them but if power trol then you can get by without as I have done it. I may have an extra set of levers, not sure. The 520 did not use the levers.
ihfan
02-13-2007 12:38:36
I have a set on a 520.
amo
02-13-2007 12:29:54
I HAVE A B AND I KNOW THEY WILL FIT AN A OR A B.
