478 newholland haybine
ric1
02-12-2007 10:19:53
i found a 478 newholland haybine a guy traded it in on a jd. it looks to be in real nice shape its always been shedded the hardly any surface rust the paint even still looks great the jd dealer wants 2500.00 for it is this a good price or not
Sam (Mo)
02-12-2007 11:05:44
 Re: 478 newholland haybine in reply to ric1, 02-12-2007 10:19:53
Ric 1
I have one I bought used. Paid $1750 for it. Man does it look rough, first owner must have hit every fence post on his place. But, the old girl runs like a champ. Just give it a good looking over and pay claose attention to the wobble box. Also check the chain sprockets for wear, those dude are a bear to replace.
I think 2500 is fair.
Sam
ric1
02-12-2007 12:24:49
 Re: 478 newholland haybine in reply to Sam (Mo), 02-12-2007 11:05:44
what do you mean by the wobble box do you mean the gear box
Sam (Mo)
02-12-2007 12:32:09
 Re: 478 newholland haybine in reply to ric1, 02-12-2007 12:24:49
talking both but the big ticket item is the wobble box. I had to replace the top chain sprocket off the gear box on mine two years ago, teeth were worn out. Man that was a job, really hard to get to.
Eric SEI
02-12-2007 18:55:34
 Re: 478 newholland haybine in reply to Sam (Mo), 02-12-2007 12:32:09
Check that top sprocket. Ours was bought new, we eventually had a problem. The top sprocket was only attached on one side, so of course it went out. Installing the new one properly was a pain, at least the way we did it, maybe there was a proper way we didn't know about.
As a farmer, my Dad was a good research chemist (retired).
ric1
02-12-2007 19:08:02
 Re: 478 newholland haybine in reply to Eric SEI, 02-12-2007 18:55:34
i thank you all for your input tommorro ill stop and check it out a little closer and ill let you know what i find?
old
02-12-2007 12:29:59
Wobble box is the part that makes the sickle bar go back and forth. They have bearings etc that wear out and can be fun and cost a fair bit to fix. Also the rollers are a big thing to look at. If they are comeing apart they can cost a lot to fix also, more then the machine is worth for that matter at around $1000 each
KEH
02-12-2007 15:56:48
 Re: 478 newholland haybine in reply to old, 02-12-2007 12:29:59
Check oil in main gear box,sometimes they get water in them. I'm a believer in changing the oil in them once a season anyway.
KEH
