Mounted plow and cultivator
mwilke
02-11-2007 07:56:06
Does any one have pictures or know where I can see pictures of a mounted plow on a Farmall C?
I think I am missing a part on the front that mounts to the tractor lift and the plow itself.
Also, pictures of a cultivator on a C would be appreciated.
Thanks
mwilke
02-11-2007 14:25:43
 Re: Mounted plow and cultivator in reply to mwilke, 02-11-2007 07:56:06
Thanks for the responses so far. I should have mentioned that is not fast hitch setup. The plow, I think, hooks up with a long hitch going under the tractor similar to a cub.
Larry in GA.
02-11-2007 12:22:58
I have a two bottom fast hitch for my Super c if that is what you need I will take some pictures next week when I hook it up to go to plow day. I have the two row cultivator on it now and will be taking it of next week and can get you some pictures if that will help I don"t rember seeing to meny c with plows in the galleries. Larry
Hugh MacKay
02-11-2007 11:34:12
mwilke: One place you might try is tractor photo gallery. Just type in Farmall C, save looking through all. I never tried this, however you might try typing Farmall C with plow. Problem with that idea, if the person didn't post it way you will miss it.
