Manure spreader beater bar
Chip S.
03-05-2000 05:47:37
I have an old IH 100 spreader with an auger type beater bar. One of the brackets let go and bent the shaft and one of the augers all to heck. I'm looking for a replacement auger. Thought about making them, but I don't have a press.
Anybody know where one can be had?
Tom(Pa)
03-14-2000 08:43:03
 Re: Manure spreader beater bar in reply to Chip S., 03-05-2000 05:47:37
I just cut out one auger for my 100 spreader. The outside circumference is 42 inches. +a few tenths. The diameter is 23.5 inches with a 11 inch hole cut out of the center. drilled the mount bolt holes in each end (2 each end) and used my hylift jack to spread the ends. ran wire thru the holes and put one loop under the foot and the other loop over the jack point. The augers for the 200 are a little larger and Have not been near one recently. hope this helps
