Hay Crimper
Gene Andrews
02-04-2007 12:39:54
I am looking for a hay crimper and was told that this is the place to find anything anybody would need. I would really like to find a Cunningham hay crimper or a John Deere hay crimper but it would have to have the to big mesh steel rolls.
any information would be greatly appreciated Thanks Gene
johns48jdb
02-06-2007 04:28:03
 Re: Hay Crimper in reply to Gene Andrews, 02-04-2007 12:39:54
i'm in n al and have a hesston mower/conditioner 7 foot wide cut that i'd sell for 500.00 if your close to me. it worked well two years ago and has had the belts and drive mechanism covered good since then. it could stand some minor work on the rollers as some of the 1 inch channel pieces that are welded to the rolls are missing in different lengths at several different places on the rolers. wouldn't be bad to fix at all. i used it one year and have gotten out of the hay business. the machine ran and preformed real good the year i used it. i rebuilt the blade and only cut 5 acres with it twice.
wayne from wi
02-05-2007 14:08:12
Where are you located? I have a John Deere crimper, actual crimper type, sitting behind the shed that I haven't used for years. It s still OK. If it sits there another year or so, it might turn into a saw rig for firewood. If you are interested, my email is open. I am in central Wisconsin.
Gene Andrews
02-10-2007 16:55:41
 Re: Hay Crimper in reply to wayne from wi, 02-05-2007 14:08:12
I live in Darlington Wi. It is about 1 hour south west of Madison. I need to know if it has steel meshed rolls and if they are the same size. Thanks alot Gene
wayne from wi
02-12-2007 07:28:57
 Re: Hay Crimper in reply to Gene Andrews, 02-10-2007 16:55:41
Hi Gene, The crimper has 2 steel meshed rolls, the bottom one is much smaller than the top one. I live in Curtiss, Wi. Wayne
Carp
02-05-2007 08:41:25
I have a NH crimper. It has steel rolls and works well. I am in SE Ohio. e-mail me if you are interested.
Gary from Muleshoe
02-04-2007 14:32:05
There is a Cunningham list in phote ads. I believe it is located in MD.
