vermeer 605c bearing
cjr17
02-01-2007 14:40:06
Last summer the very last roller bearing(the last roller on the gate to let the bales out) went out on my bailer, we found this out by catching the machine and field on fire but luckily the fire didn't catch the belts and was extinguished quickly. Now i was wondering how to replace the bearings in the roller. I can easily take the bunch off but cannot figure out how to get them apart to replace it. Any help would be greatly appreciated. Thanks in advance
CJ
joe-etx
02-01-2007 18:29:46
 Re: vermeer 605c bearing in reply to cjr17, 02-01-2007 14:40:06
if close to east texas,will give 605c baler that worked 6-10 years ago. NEED PARTS?
504BALERGUY
02-01-2007 15:04:34
Remove the roller from the baler. There are roll pins holding each shaft cap on. Remove the roll pins and knock the shaft caps off. More that likely you will need to heat the shaft caps and hit with a large hammer. If you can get the roller in a press that would help a lot. When the shaft caps are removed remember how they go on. The shaft and the cap are drilled at the same time, so they are a match fit. Once the caps are off you can press the shaft out of the roller. Then the bearings will come out of the ends.
cjr17
02-02-2007 16:16:18
 Re: vermeer 605c bearing in reply to 504BALERGUY, 02-01-2007 15:04:34
Thanks for your help, atleast now i'll have an idea of what to do
El Toro
02-01-2007 14:54:00
You should post a closeup picture. Hal
