Dearborn Manure Spreader
Rob in Missouri
01-30-2007 19:05:49
Need to find manuals for model 1983 dearborn manure spreader. thank you
Leroy
02-01-2007 16:05:28
 Re: Dearborn Manure Spreader in reply to Rob in Missouri, 01-30-2007 19:05:49
I think you need to refigure out what you actually have. The Dearborn name ended at the end of 1954 with Ford replacing it in 1955 and the Dearborn model would be a code number with a dash in it. The old Dearborn spreaders were actually Oliver just painted red instead of green and about 50-60 bu. capacity. Now if you are talking a 1983 year spreader if it was made by Ford it would be painted Blue and would be a PTO powered spreader instead of ground drive on the Dearborn and older Red Ford spreaders.
Rob in Missouri
02-01-2007 17:21:07
 Re: Dearborn Manure Spreader in reply to Leroy, 02-01-2007 16:05:28
Leroy you are probably right. My son gave me those numbers as a serial number but probably misread it.I am sure it was made in the 50's and is a Dearborn-no pto. I'll check it again. Thank you
