Name of this implement
Wild one west
01-26-2007 05:43:03
third party image
What is the proper name of the tractor Implement that makes rows (furrows) in the ground for flood irrigating hay fields? Here in Colorado we call it marking the field. The one that I've been using for years is the neighbors and it appears to be home made, only three blades that are sharpened down to nothing and I don't think it will stay together another year of use. So I think it's time to buy one rather then making one. Here is a picture of one I'm thinking of buying for $250.00 The problem I see is that the blades are mounted on springs instead of being mounted rigid as in the neighbors. The seller says it's a John Deere and he calls it a Cultivator bar. Is this what I'm needing for marking? And what is the correct name of this implement? Any advise would be appreciated.
Chris
Hotchkiss, CO
bizkit
01-27-2007 14:44:46
 Re: Name of this implement in reply to Wild one west, 01-26-2007 05:43:03
the word ur looking for iz lister that what we use
bizkit
01-27-2007 14:44:39
Glen in TX
01-26-2007 20:15:07
I seen others got fancy names for them lol. Cultivator or pulling out rows or furrows here. To me it's a just a diamond tool bar with a three point hitch. You can hang anything on them you want that fits the diamond bar, spring shanks, rigid shanks, curved culitvator shanks, furrow dikers, row crop planters, crumblers, bed shapers. Different sweeps, lister furrowers, or chisels can be mounted to the shank foot. The coiled shanks were probably originally designed for use with anhydrous ammonia fertilizer applicator knives. Here the diammond bars don't bring much anymore with everyone wanting a HD 4x7 bar or 2 or 3 row 4x4 bars. Do you really need furrows for irrigation? Is the other one you mentioned more like chisel or subsoiler or one of those pasture renovators? Here are some sites that may or may not have what you are looking for with most being made for applications in my area. bighambrothers.com brownebrosinc.com rollacone.com loreznomfg.com
paul
01-26-2007 19:58:04
Here in my part of Minnesota we do whatever we can to try to dry out the ground, so I have no idea what all you use to add water to ground.
The top frame is likely a 3pt tool bar, used for many things.
The shanks with the wound spring part is very common 'here' only on anhydrous applicators. These need to go pretty deep, with a very narrow knife on the bottom to put anyhdrous 6 inches or deeper into the ground. I know of solid shanks (might be a spring or shear bolt right by the shovel/sweep); C shanks (light ones for field cultivator, heavy suckers for chisel plows), Danish shanks (light springy S shaped), and these wond coil things for anyhdrous applicators.
The sweeps/shovels you have on it (the part that cuts the ground) are very large sweeps, would be quack sweeps around here, likely hiller or some such name in your location. They are bigger than your typical field cultivator or row crop cultivator sweeps, which are often 4-8 inch - yours look huge. Typically chisel plow sweeps are only 2 or 4 inches wide with no 'feet' on them, just a point. So yours are real wide cultivator sweeps, or likely quack digger or some other local nick name.
I'd guess your machine is bolted together from several different sources to do what needs to be done. Around me, nothing comes from the factory looking like that. Perhaps they are a specialized machine & only sold in your climate & region. A hiller, or lister, or bed builder? In my rocks, hills, & mud, we don't use nothing like that. :)
--->Paul
FreeRanger
01-26-2007 13:50:43
 Danish tines with sweeps on a field cultivator in reply to Wild one west, 01-26-2007 05:43:03
Here in Southern Wisconsin, we don't irigate. Very hilly and rocky to boot.
I purchased a green implement identical to yours about five years ago only slightly different setup. Mine is wider with I think 7 tines, three forward and four back? Instead of wide sweeps at the end of the tines, I have narrow sweeps (like spikes). I might replace them someday with wide sweeps because I took two front tines off to use this implement as a row cultivator for my two row corn planter. I have some shields from a different cultivator.
I am told those "spring" tines shown in photo are known as "danish" tines around here. I have another field cultivator with true "spring" tines. the tines are hinged at the bar and have dual heavy duty springs on each tine. Again this implement has spike sweeps not wide sweeps. By the way "springs" break when you go too deep and hit the bedrock.
I use both implements as a poor man's subsitute for a plow. So yes I do pull them across sod to break it up. Yes they can go deep (12") if you adjust your top link and 3pt correctly. I run a disc with drag afterwards to prepare for planting.
Most farmer around here never plow. They run a cultivator implemnt with danish tines up front row(s) and disc(s) in the back and maybe a drag as well. One or two passes over beans/hay and the field is ready for corn planter.
FreeRanger
01-26-2007 14:05:14
 Re: Danish tines with sweeps on a field cultivato in reply to FreeRanger, 01-26-2007 13:50:43
Yours actually looks identical to mine only someone has removed half of the tines on the one you are looking to purchase. Ask the seller if he still has them. Mine is not any wider and is JD green.
Fleet Farm calls your style by three different names: field cultivator sweeps, row crop sweeps, chisel plow sweeps.
Fleet Farm calls my style: chisel spikes, spring tooth points, cultivator quackers and tooth sweeps.
I think John Deere would have sold this implement as field cultivator to replace a plow. The spacing of tines is too close for row crops like beans unless you went real slow.
Rick Kr
01-26-2007 12:01:10
Chris,
We call that a cultivator. Use them to mark fields for planting trees. You set the row width you want and drag it east/west, then north/south. Then plant at every intersection and the whole field is then 8'x8' spacing. Or add tines in one direction to get 4x8 or whatever you want.
Also use one with many more sweeps to cultivate between tree rows to keep down weeds.
Your field has to be worked up, that will not cut sod.
I buy 1 or 2 a year of what you have in your picture, anywhere from $10 to $70 at auctions.
Nobody uses them around here anymore.
Good luck,
Rick
WyoDave
01-26-2007 09:36:19
We call it a "Corrugator" here in Southeast Wyoming, and what you have pictured is a very simple "cultivator". I do close to 1000 acres every spring, and the machine in your picture, in my opinion won"t work very well. First of all, you don"t want to make such wide ditches. 3-4 inches would be much better, granted you could change that pretty quick. Also, most corrugators have more weight (so they will dig into hay fields), and most have a way to control depth. Also the springs on the pictured machine will cause the ditchers to bounce along the surface of the field and not "dig" like you want them to. All corrugators I"ve seen have the ditchers mounted solid. Myself, I use a homemade one that I built from a roller harrow, and if you want I"ll send you pictures. I"ve tried several manufactured ones and was never satisfied by the results. E-mail me if interested in photos. David
Allan In NE
01-26-2007 06:31:10
Hi Chris,
Yes that is a plain old-fashioned John Deere cultivator bar and we over here in Nebraska call it "corrugating" the field.
Also used for roughing up bean ground in the winter so that it won't blow.
I like the Lilliston cultivators fitted with ditchers to do what you're talking about. They can be bought for almost nothing anymore.
Is your fields fairly level? They can be boardered off also and it leaves the field a heck of a lot smoother.
Allan
third party image
Wild One West
01-26-2007 07:58:27
 Re: Name of this implement in reply to Allan In NE, 01-26-2007 06:31:10
Hi Allen, All of the fields are slightly sloped as to not erode the soil and just enough to Carry the water nice and slow and allow the water to soak into the ground. That picture of your Lilliston cultivator looks like its complicated to me, But I wonder if cutting the roots of alfalfa in the spring while using something like your Lilliston would help with growth. Have you heard of a implement called a "triple K" I over heard some farmers talking that they use it to tare up the roots and making the alfalfa fill out even heavier. I think this is done before marking the fields in the spring. I'll have to check into that. After my last cutting and first heavy frost I turn out my mules and horses for the winter on my hay fields and then in the spring before I mark my fields I'll drag a harrow (as we call it out here) over the fields to brake up the manure. Thanks again,
Chris
Hotchkiss, CO
Allan In NE
01-26-2007 08:09:54
 Re: Name of this implement in reply to Wild One West, 01-26-2007 07:58:27
I dunno,
I've never "redone" a field. Corrugate it good before planting and it is good for the duration of the field usually 5 to 7 years because that alfalfa won�t let the soil �move�.
Yep, splitting the crowns will rejuvenate a tired field of alfalfa.
If your fields are even close to being on the level, boarding is by far the better method.
Allan
John (MO)
01-26-2007 06:30:55
Hey Wild,
The same tool is called different things in different parts of the country, sometimes even by 2 people who live side by side. Sure does complicate things. The picture you posted is what I would call a cultivator or rear cultivator bar. In most cases it would just be a part of a full cultivator. In my opinion it is mostly just designed for loosening worked ground behind the tractor as you cultivate a crop. It does not go into the ground more than a few inches and then in worked ground, not in sod. I think what you want is something that I would call a ripper. We don"t irrigate much here so from that angle I am lost, but for me a ripper is a tool that would go down into the ground much deeper than any plow and would break up the hardpan that gets formed. I"d like to say that they get down to the freeze line where ground wouldn"t normally have any tendance to loosen it`s self from freezing and thawing, but I really doubt most rippers go quite that deep. The do go down around 15 inches, maybe down as far as 24 inches, if you got one heavy enough to stand that, and the horses to pull it at that depth. I don"t see anyway you cound have a tool that goes that deep and have it made with springs or of a spring. It would be stretched out straight back instead of straight down most of the time if that were the case. Now if you just need to loosen the very top of the soil, say right under the grass roots, you might get by with a tool like in the picture, but even then you are going to have to go with a shovel without the sweeps or wings on it. I just doubt it a little scratching with a tool like that will help enough to get the water down into the subsoil. But again, I"m not in an area where grass or hay is irrigated by anyone but the big Guy upstairs. Hope my long winded saga helps a little.
John (MO)
01-26-2007 06:45:37
 Re: Name of this implement in reply to John (MO), 01-26-2007 06:30:55
A quick look at the ironsearch.com sight shows the tools that I am thinking of called rippers, V-rippers and subsoilers, who knows maybe even other things. I can`t seem to get a picture of one of them to attach here though.
Rich Va
01-26-2007 06:30:45
We call it a tool bar here with flex shanks. We call the blades sweeps. Folks call it different things in different parts of the country. Long time ago we would have used something like that with front mounted cultivators to split the middle and scratch out the wheel tracks,only it would have had three shanks.
johns48jdb
01-26-2007 06:21:40
in n al we would call what you"ve been using a pasture rentavator. it just breaks up the crust without really making a furrow. what your looking at now is what we call a field cultivator on spring shanks. the spring shanks will vibrate and penitrate down into real hard ground. i"ve been told that they would take the ground when stiff shaked one wouldn"t. i"ve never heard of doing what your talking about in a hay field. do you pull a leveing drag of some kind back in behind this plow to smooth the ground back down so you can get across it with a hay mower? my 4 cents. price on everything has gone up, but gas is coming down. 189.9 in n al
Wild One West
01-26-2007 07:26:50
 Re: Name of this implement in reply to johns48jdb, 01-26-2007 06:21:40
Hi johns48jdb and everyone else For those of you that do not flood irrigate using a marker, This is how it is used. The marker is used to cut furrows from the main water supply ditch down to the other end of the hay field to allow irrigation water to flow and irrigate instead of using sprinklers. The furrows are cut every spring before the water is turned on for the season. The furrows are about 24" apart and cut deep enough (3"-6") to carry the water down. The marker in the picture has 4 sweeps (blades). I'll irrigate 24 to 48 furrows in a 12 hour time depending how much water I'm getting and then move on to the next 24 to 48 furrows. I cut the hay on the outside parameter of the field first which is the bumpiest and then I cut parallel with the furrows so it's not so bumpy. This is the way most of us irrigate in this part of the country. When I lived in northeastern Nevada everyone mostly used pivots and/or wheel lines which is fine but the prairie dogs and gofers could get out of hand destroying a good part of the hay crop which was another matter of it's own. I would trap 3000 gofers a summer and shoot just as many prairie dogs in 160 acres of hay and still be out of control. Thanks for the advice and info on this subject, I'm learning something every time I go to this good web sight!!!
Chris
Hotchkiss, CO
ShepFL
01-26-2007 08:14:23
 Re: Name of this implement in reply to Wild One West, 01-26-2007 07:26:50
third party image
I understand the concept of flood irrigation. In FLA we call the pic a cultivator or spring shank cultivator. It is used to mechanically uproot weeds in row crops.
I think what you are after is what we call a ripper. See pic. Mind you this pic is just a humorous response to Allen NE. These rippers or sub-soilers are generally used to break up hard pan allow better root propagation and water absorption.
As an alternative to maintaining the waterways as you described would it be more cost and yield effective to do as they do in AZ. See link below for more information.
They have concrete raceways around cotton and corn fields and fill them with water until the entire field is flooded; generally done in the mornings to prevent evaporation.
I understand that they can recover most of the water for reuse. Not sure of the initial cost and payment terms on capitalized asset or any local water rights issues. However, if fields are in constant production this might be a more effective solution in the long run both in terms of production and population control on the gophers.
FWIW,
ShepFL
Rick Kr
01-26-2007 12:09:35
 Re: Name of this implement in reply to ShepFL, 01-26-2007 08:14:23
Shep,
Are you trying to intimidate Allans red tractors?
How much HP are you turning to pull that?!?!
Another picture like that and Allan might be seeing "green".
I do like the picture. Had to move a big disk one time with a 20hp Kubota. Poor tractor would hardly move it with it up.
Rick
johns48jdb
01-26-2007 08:13:41
man i'm glad we don't have to do that down here in n al. i can only imagine how much dust you must stir up when cutting and raking the hay. sounds like an awful lot of work on top of that. i use to cut hay for the public. we tried to put up a thousand square bales by hand everyday. i always put myself as the next to the last guy in the barn lofts. i would have a guy or two above me and i would throw the hay to them and let them stack it. i'd have to have enough guys to get the hay off the trucks and to the back of a fifty foot long barn in some places. i would always plant my feet and have the guy feeding me put the bale on my feet. i would twist my back and throw the bales where needed. now i take shots every 3 months for back pain. planting your feet and twisting your back with a load is not the thing to do. now they tell me!!!!!
Gary in Utah
01-27-2007 00:49:09
 Re: Name of this implement in reply to johns48jdb, 01-26-2007 08:13:41
I hear you, Bro. I spent my youth throwing bales and am paying for it now. Why didn't somebody tell us?
