John Deere 14T square baler
Lynn Busby
01-25-2007 10:31:25
How reliable is this type of square baler? Approximately when were they made? How much should someone expect to pay for a used one? Thanks
centralilbaler
01-27-2007 17:18:24
 Re: John Deere 14T square baler in reply to Lynn Busby, 01-25-2007 10:31:25
Up until a few years ago, i had a 14T. It was a very reliable baler. About every 2 rack loads a shear pin on the flywheel would break, and thats about the only problem i"ve ever had it. A fellar does need a break every once in while.
two mile
01-26-2007 21:49:57
We bought ours at a local farm sale 3 years ago. I knew the family and was confident that this unit was mechanically sound. I think we paid $650. We have put over 3000 bales of straw through it. It misses about 1 in every 200 bales. Usually a knot stuck on the billhook. Having a lot of gear choices in the 2 - 4 mph range will help you be more efficient with it. I've been very satisfied.
bradk
01-26-2007 17:37:31
third party image
Here's ours.Very good old balers.Reliable as heck.~brad
j cook/iowa
01-25-2007 20:21:27
I think that the first 14T came out in about 1955. My dad had one with a ~500 or so serial number and IT was a 1955. They were built until about 1963 and so are all 45-50 years old. That generally means that they are worn out. SOME may not be, and still more have been repeatedly rebuilt and overhauled to the point of having many new(er) parts in them---but they are STILL pushing 50 years old,
ANY machine of this sort, with this many moving parts, be it mounted corn picker, pull type or self propelled combine, baler, forage harvester, planter or whatever, will be seriously worn out by this stage of it's career and while I won't say that such a machine can;t be made to work, probably one ought to be thinking slightly newer if one is wanting a WORKER as opposed to having a RESTORED SHOWPIECE!
This would apply to an old IHC baler or an old NEW HOLLAND or FORD or OLIVER baler as well. How much work and parts dollars are you willing to invest to keep it operational?
As for what did the 14T USED to be? They WERE one of the better balers made---in their day! Having had one in my family for over 35 years (until it finally wore out) and having put literally over 100,000 bales through one I'd say they were pretty darn good. I'd rather use something more like a 337 today, however (which is what I bale with)!
Hard Knocks
01-25-2007 12:46:29
They are a pretty good baler but the JD 24T and the 336 were a big improvement
old
01-25-2007 10:54:37
14T is a good OLD baler made around 1956 give or take a few years. All the ones I ever owned and I have had 3 or 4 of them I payed around $300 for. If they work they are good but if they have problems they can drive you crazy tring to fix them. Nice thing is you can still get most parts for them and you can even get the manual from JD for around $30
Dave H (MI)
01-25-2007 14:44:29
 Re: John Deere 14T square baler in reply to old, 01-25-2007 10:54:37
Thar you go agin! Trying to blame your mental health issues on some nice old iron! Good to see you back. Must be all dug out, eh?
old
01-25-2007 15:43:54
 Re: John Deere 14T square baler in reply to Dave H (MI), 01-25-2007 14:44:29
Not really just enough to be able to start doing a few things here and there. I still have tree limbs all over the place and a hole in the roof which I have to wait to fix till it warms up a little more. Then today my wifes car brakes down and I have to get a new CV joint for it. Oh well I'm not bored
Jonfarmer
01-25-2007 10:44:31
I got one. They are reliable when they work!. Alot of them are all worn out so watch out for that since the are so old. I don't know when exactly they were made, sometime back in the 1950's I guess. My biggest complaint is the pickup head is the poorest design JD ever made (it was after all the first baler JD ever offered) it really doesn't do well with short hay, but in big windrows of nice long hay, it will work ok. I'd never pay over $500 for one and because they are so old, I'd want to see it work first if I could.
TimS in Mo
01-25-2007 10:41:46
I had a 14T, it was my first baler of any type....but I bought it in 2004, sold it last summer to change to round baling.
Properly adjusted and maintained, a 14T is a good reliable baler. If you haven't worked on one before, adjusting the knotters can be a bit of a challenge until you get the hang of it.
It's an older baler, made in the early 50's to early 60s I believe. It is also a lower capacity baler which means it has a narrower pickup and can't process a windrow as quickly as the newer higher capacity balers.....
Price wise varies on condition, etc. I paid around $400 for ours and sold it for $1200 so I did well on that deal. I also put all new chains on it, changed the right side bearing on the crank, and did a lot of odds and ends to get it up to snuff.
