John Deere 535 round baler
Fabr
01-23-2007 12:33:35
At end of hay season the tie arms went through half of a cycle, they are currently all the way to the left. We have engaged the hydraulic pump manually, but the arms will not return to the start position. Does this sound like a bad pump or could it be the cylinder?
Thanks
Tx Jim
01-23-2007 12:45:30
 Re: John Deere 535 round baler in reply to Fabr, 01-23-2007 12:33:35
Lock tailgate with valve,raise tension arm inside baler so that you see 3+ in bale size indicator window on front of baler. Engage pto and pull rope,twine arms should cycle and return to home position. Tx Jim
Fabr
01-24-2007 05:00:31
 Re: John Deere 535 round baler in reply to Tx Jim, 01-23-2007 12:45:30
Do you need to continue to raise tension arm during entire procedure. What is the safest way to do this.
Tx Jim
01-24-2007 05:50:04
 Re: John Deere 535 round baler in reply to Fabr, 01-24-2007 05:00:31
If there are no broken springs on pump linkages then you shouldn't have to raise tension arm or do anymore than what I stated earlier. As long as 3+ is in window twine arm should cycle with pto engaged. Tx Jim
