Weight of JD 55ABH plow needed
Gary Wooldridge
01-19-2007 11:13:14
Hi, I am building a pole building, and I want to have one of the trusses built so that I can off load my JD 55 plow from my trailer, using an hoist mounted to the truss, and need to know how much one of these weighs ?
Can anyone help? The manual does not list a weight.
TNX
Dave from Texas
01-22-2007 10:33:06
 Re: Weight of JD 55ABH plow needed in reply to Gary Wooldridge, 01-19-2007 11:13:14
My front end loader is rated for 1000 lbs. It would not pick it up. I would say 1200#'s
johns48jdb
01-21-2007 15:58:38
why not put a steel beam across the headers that the truss sit on and not take the chance on breaking a truss. you could construct an a frame out in the yard some place by setting some good size poles in the ground and getting a steel beam to go across it. a good chain hoist hooked to a big chain across the beam should do the trick. i would want to take the chain hoist down in between times so it want rust up seting out in the weather.
Gary Wooldridge
01-21-2007 17:06:19
 Re: Weight of JD 55ABH plow needed in reply to johns48jdb, 01-21-2007 15:58:38
My builder can add to the trusses, just costs more, the span is 48', I was just hopeing that somone would know off the top of their head.
TNX
Lou
01-22-2007 10:53:40
 Re: Weight of JD 55ABH plow needed in reply to Gary Wooldridge, 01-21-2007 17:06:19
Wow 48 ft that a long truss, bet theres a cheaper solution.
Randy as in Randy-IA
01-21-2007 11:08:41
Hi The easy solution is weigh the trailer empty , load the plow and weigh it with the plow on it . Takes some time but that's the weight you need to KNOW as opposed to GUESS . What the heck ! Build it to take 2 tons or more , because if you lift the plow you'll want to lift other things as well in time . Might as well prepare for it now . ...Randy
Gary Wooldridge
01-21-2007 17:03:22
 Re: Weight of JD 55ABH plow needed in reply to Randy as in Randy-IA, 01-21-2007 11:08:41
U are right! Unfortunately due to location and distance, it would take me two days to do this.
TNX
rfdeere
01-19-2007 15:25:20
Well, it depends on how it is equipped. I would say low side 1000 lbs. High side 1500 to 2000.
