Handy as a shirt on s pocket!!
wh
01-11-2007 07:17:40
third party image
just finished this hay spear. added the stands so that the owner would not have to "rassle" with it when hitching to it. the stands will rotate 90 degrees and slide up under the cross arm out of the way.
RickL
01-13-2007 05:51:57
 Re: Handy as a shirt on s pocket!! in reply to wh, 01-11-2007 07:17:40
If this is for three point hookup where is your other two lower brackets for the lift pins to go thru
wh
01-13-2007 10:54:12
 Re: Handy as a shirt on s pocket!! in reply to RickL, 01-13-2007 05:51:57
will be using the bolt on lift pins.
El Toro
01-11-2007 13:18:46
Nice job fabricating and welding. Hal
redlevel
01-11-2007 09:15:36
Neater'n grits and not near as lumpy!
