jd 71 flex planter
npuller
01-09-2007 18:06:46
hi all need a seed plate part number for watermelons for the 71 flex planter.thanks
Brendon
01-09-2007 20:11:13
 Re: jd 71 flex planter in reply to npuller, 01-09-2007 18:06:46
I cannot find any plates in the Deere catalog specifically for watermelons, but I'm sure there are ones that would work. A fairly thin plate that is used with a filler ring would probably be your best bet. You might also take a look at some of the plates Lincoln Ag Products lists for sunflowers since the seed shape is similar. They list the cell dimensions of all their plates on their website.
Henry Steinberger
01-17-2007 06:37:27
 Re: jd 71 flex planter in reply to Brendon, 01-09-2007 20:11:13
You can also buy a blank plate from lincoln ag products and I would trace out the size of seed (use a dremel to cut the seed size out) and I would also suggest the use of a filler plate.
npuller
01-09-2007 20:31:57
thanks Brendon. sunflower plates could work.
jhill52
01-10-2007 13:11:17
 Re: jd 71 flex planter in reply to npuller, 01-09-2007 20:31:57
If you can get one that is close you casn modify it with a file to fit the seed better.
