John Deere 535 baler
Fabr
01-07-2007 17:53:58
Dad has trouble with his 535. When we last baled the tie arms would not go through the cycle completely. It has a bale trak monitor, but we would have to restart the tie arms manually. It finally would not do anything, now the tie arms are all the way to the left side of the cycle and will not return to the start position. Any suggestions greatly appreciated.
Thanks!
cannonball
01-08-2007 04:31:38
 Re: John Deere 535 baler in reply to Fabr, 01-07-2007 17:53:58
the 530 amd 535 have 5 springs on the pump side of the baler..all must be there for it to work right... have nice day
MAY GOD BLESS THE USA
Tx Jim
01-08-2007 03:45:45
Have you checked oil level in pump and changed filter? Does belt look worn? Monitor on 535 has nothing to with actual tying only tells you what it's supposed to be doing. Do you have a manual? Be sure compressor rods aren't interferring with twine arms. Lock tailgate,raise belt tension arm to where you can see 3+ in bale size window,engage pto,pull rope ant twine arms should cycle. If they don't open twine spacing control knob and try again. I've seen times when debris gets in twine spacing orfice.Tx Jim
dynaflow
01-07-2007 18:32:58
Never open the gate with the baler running unless the tie arms are in the home position. It gives me fits but I play around with the mechanism engaging ther pump until I get the arms home, then everything works ok.
