ford 101 3 bottom plow
hypwrrifle
01-04-2007 20:08:25
My question is can you remove the third bottom and turn it into a 2 bottom plow ? Will the furrow wheel bolt up to the second bottom? Ford 101-339 model.
jhill52
01-06-2007 02:42:34
 Re: ford 101 3 bottom plow in reply to hypwrrifle, 01-04-2007 20:08:25
Yes you can I have done it. You have to move the landside side from number 2 to number 2 bottom to mount the wheel.
Mark
01-04-2007 21:03:24
I'd say yes you can. I have the exact same plow..3-14" bottoms. You might have to replace the second bottom with the third you remove, so the gauge wheel will work...never thought about it. These are the best plows I ever used.
