Whats the difference between underserrated and top
hayrookie
01-04-2007 02:36:18
Whats the difference between underserrated and topserrated Sickle bar blades. Was looking for new blades and came across these 2 types.
Thanks
msb
01-04-2007 08:06:48
 Re: Whats the difference between underserrated and in reply to hayrookie, 01-04-2007 02:36:18
Don't overlook smooth sections. They work best if the hay is real sappy,gummy and wet.
Leroy
01-04-2007 05:26:16
Underserrated have always been used on mowers for green material cutting while top serrated have always been used on combines for cutting a ripe (dry material) crop as wheat or soybeans
Wayne in Pa
01-04-2007 05:17:48
The underserrated blades can be sharpened with out gringing away the serrations, the top serrated blades can't be sharpened without grinding away the serrations. The top serrated blades can be sharpened but you will grind away the serrations and you will soon have a smooth blade. Hope this helps. Wayne
Iowanative
01-04-2007 04:21:33
On one it is serrated under the section and the other is serrated on the top side of the section. It hard to explain. no real difference.
