Quick Hitch are they any good
Donaldinky
01-01-2007 23:49:19
I have a chance to bye a Quick Hitch from a friend.. Its a class One hitch I am planning to put it on MF 135 Thanks Donald
Donald In Ky
01-02-2007 10:38:51
 Re: Quick Hitch are they any good in reply to Donaldinky, 01-01-2007 23:49:19
Thanks for the inf. My friend dad died last year and he found it in the garage its looks new but there no name on it he wants $50 His tractor is a class 2 hitch.
Thanks Donald
Easy1
01-02-2007 09:26:51
I recently bought a $69 HF quickhitch. I had looked at them for years, but I didn't want a $200 + bill. But after I got it, I had to modify it to work. It is handy for picking up my backblade or the york rake. You cannot use it for the posthole digger.
Hugh MacKay
01-02-2007 03:10:25
Donald: They are a great device, especially for big tractors, of course the reason being, big tractors have big implements. It works great on large semi-mounted plows, cultivators, chisel plows, etc. The key here is big weight.
Another factor you have to consider, are all your implements the same width at hook up point? That is a must. The vertical measurement to the top link must be the same on all implements. There are also a few implements, just by design, the quick hitch will not adapt to. I knew a guy that had to remove the quick hitch to use his MF sickle mower on his MF tractor. I can see problems associated with 2 bottom plows, but not certain.
I'd tell your friend you wish to try it, see how it will match up with all your equipment.
RickL
01-02-2007 05:25:32
 Re: Quick Hitch are they any good in reply to Hugh MacKay, 01-02-2007 03:10:25
If they fit the stuff you have they are great. they commonly fit alot of the later items. All items can be modified to fit them thou however if you want bad enough. They also put everything back about 4 inches more in mounting to your tractor
Burnie
01-02-2007 02:53:42
I think they are great espcially if you're in a situation where you need to change impliments a lot. The only problem is if your impliments don't match the quick hitch, but I reckon it's well worth the effort to modify them.
