grinder
davidky
12-31-2006 17:29:51
correct rpm when grinding corn hammer mill
paul
01-01-2007 20:59:28
 Re: grinder in reply to davidky, 12-31-2006 17:29:51
Set the tractor to the correct speed for 560, 1000 pto, or belt speed.
Or what is it you are trying to figure out?
--->Paul
Mark
01-01-2007 07:41:21
Pretty simple really. Run as much throttle as necessary to get the work done..... ..you're not going to hurt the mill. I'd say about 3/4 throttle would be a good place to start.....if the tractor chokes down.....give it more fuel.
R.J.
12-31-2006 18:57:43
if your grinder has 540 shaft then crank up to 540 useing the tack, if 1000 then do the same with tack and grind on. Mine has a 540 shaft so i crank up 540 and let it rip.
R.J.
12-31-2006 18:54:30
Fancy Farm
12-31-2006 18:26:32
What Kind of hammermill
fixerupper
12-31-2006 17:50:21
The two hammer mills I have been involved with both had a decal saying '3600 RPM' by the hammermill shaft. Jim
steveormary
12-31-2006 20:07:17
 Re: grinder in reply to fixerupper, 12-31-2006 17:50:21
It has been a long time but isnt feet/minuet posted by the belt pully on the grinder. Pto grinder should have 540 or 1000 rpm for pto speed. We had an old belt driven hammermill and later a Letz burgrinder that was pto drive.
davidky
01-07-2007 17:39:50
 Re: grinder in reply to steveormary, 12-31-2006 20:07:17
sorry took so long harddrive crashed seems to work good at 3/4 open . thanks to everone
