Simplicity 4041
walker45
12-30-2006 21:45:16
I have a 4041 Simplicity 19.5 hp trying to find some implements for it bush hog and box blade what kind of bush hog can be used on this tractor is there a certain type to look for such as a certain PTO rpm rate or something else any suggestions or links for this will be appreciated.
mowr
01-05-2007 07:14:24
 Re: Simplicity 4041 in reply to walker45, 12-30-2006 21:45:16
Requires equipment designed for Category 0 3-point and PTO (2,000 rpm). Any mower shop that handles GARDEN tractors (as opposed to yard tractors or lawn tractors) should have access to all kinds of attachments and equipment compatible with your tractor. simpletractors.com might be a good place to start learning more about your tractor. I believe the 4041 should have an Onan engine rated at 16.5 HP unless it has been replaced or upgraded. Upgrade/conversion kits are available from companies like smallenginewarehouse.com with Honda 24 HP engines.
