disc bearings
tractormiallis
12-30-2006 16:04:32
Need to replace bearings on an axle on my 10 ft disc I just got. Ordering a new round axel through shoup, which is 1 inch diameter. I need to find beearings for it. I looked at shoup, and have not seen any 1 inch bearings for disc harrows. Where can i find them? I need the flanges with bolt holes 3 1/4 inches apart.
The old bearing looked to be 1 3/16 inches diameter hole. Any ideas?
El Toro
12-31-2006 09:22:44
 Re: disc bearings in reply to tractormiallis, 12-30-2006 16:04:32
third party image
Here are some bearings with one inch holes. Northern Tool at 1-800-533-5545. Hal
`Bernie in MA
01-01-2007 09:37:48
 Re: disc bearings in reply to El Toro, 12-31-2006 09:22:44
baileynet.com has a lot of bearings.
tom harvey
12-30-2006 16:23:12
IF you have an oliver or white www.agri-supply.com has these round bearings item number 36406 for $7.49 this is a good company to do business with. I have a oliver 252 and I put one of the square axles they sell in it the only problem was I had to replace all of the spacers as the square axle is 1-1/8" but I think I will like it better as these 1 3/16" bearings can turn on the axle.
Tom in Maine
tractormiallis
12-30-2006 16:26:51
 Re: disc bearings in reply to tom harvey, 12-30-2006 16:23:12
Forgot to mention the disc is a older Krause model 4, 10 foot.
Joe(TX)
12-30-2006 18:30:47
 Re: disc bearings in reply to tractormiallis, 12-30-2006 16:26:51
My 411 (11 ft) Krause has an 1 1/2 shaft. The only other size I thought Krause offered was 1 1/8. If the bearing appears to be 1 3/16, the a 1 inch shaft is way too small. it would need to be 1 3/16. Maybe you needed a 1 1/8 shaft.
tractormiallis
12-30-2006 19:56:56
 Re: disc bearings in reply to Joe(TX), 12-30-2006 18:30:47
Ok, just measured with the calipers. The axle is 1 1/8 inch diameter. Which bearings would i need to get? The 1 1/8 or the 1 3/16? Also should I go with sealed, as it is now, or greaseable. This is my first disk ever to have owned.
Leroy
01-01-2007 05:37:48
 Re: disc bearings in reply to tractormiallis, 12-30-2006 19:56:56
Bearing and shaft size will always be the same, otherwise it would be like putting on a wore out bearing
