I have a Vermeer model 211 made by PZ Zweegers in Holland. It is slower than a disc mower because it is only about a 6 or 7 foot cut, depends on how your tires or stabilizers are set up,but you don't see then in a pile behind the Implement Dealer's shops like you do disc cutters. The dealer don't want you or anyone else to buy a drum mower because he can't sell parts! Drum mowers don't need parts for a long time compaired to all the attention and $$ you MUST give a disc mower to get the same exact acres that you will out of a drum mower. You can call Mr. Ted Perfect in Elko, Ga. He can tell you anything you would ever want to know about the two types of mowers. His Phone # is 1(478)987-1002. The other man is the HayDr, and will probaly respond to your question on here. I use a 1975 165 MF with my drum mower. No problems. You see the Fire Ants from South America, {Illegal Aliens}, have put the old cycle mower out of business down here in the south. The drum mower hits a big antbed, {12-16" high}, it only makes a little grunt, whereas the cycle mower is cloged up. I have been told if it were posible to turn the drum mower up on it's side while running PTO speed, the drums would travel at a rate of 200 MPH. I bet the HayDr will have some technical data on this. My blades cost about $1.50 or so and it takes 4 per drum the way it is set up, now I think you can have more or less blades if you want. The blades are reversible and I usually get 8 acres with the antbeds and such before swapping them to the opposite Drum. swap time is about 1-2 minutes The down sides are: 1. Hard to hook up to by your self the first time. 2. When in transport position, there is a lot of weight hanging out back. I got weights on the front. 3. To cross the road you either drag your mower on the pavement or put it in transport position which is done manually. All said mine is not going anywhere! Other folks will have more details for you on this subject I'm sure. Good luck Sir; South Ga. Plowboy
