Plow shares
MAC
02-29-2000 08:18:23
I've got a Ferguson three point double bottom plow that needed new shares. I got a replacement set, NOS. Both shares are identical and now find the front share mounts ok, but the rear share has one mounting hole about one inch off location with respect to the hole in the mounting saddle. Would it be ok to drill a new hole in the share and leave the incorrect hole unplugged or should I weld it up? Also I was told my plows were 14 inch and my new shares are marked 12. Can they still be used? Thanks in advance for any help you can give.
Gerald J.
02-29-2000 13:17:54
 Re: Plow shares in reply to MAC, 02-29-2000 08:18:23
You won't drill the plow shares. Your drill bits will melt trying.
You probably want 14" shares. You want the hole plugged, easiest to do with a spare plow bolt.
Gerald J.
