disc axles 1 size
tractormiallis
12-26-2006 15:20:33
Repairing a Krause disc I bought with a bent axle and torn out bearings on one gang. Looking at a new axle. It is 1" diameter. Disc is 10ft.
Who has such sizes? Alredy looked at Shoups.
If it cant be found, it is possible to press it out and weld the spot the torn bearing cut away.
TA in LA
12-26-2006 16:35:39
 Re: disc axles 1 size in reply to tractormiallis, 12-26-2006 15:20:33
Give Agrisupply a call. They are most helpful and will have what you need in stock probably.
http://www.agri-supply.com/
Gerald J.
12-26-2006 15:48:08
CALL Shoup. Their printed catalog says they can make disc axles from 7/8" diameter to 1-1/2".
Or a welding and machine shop should be able to make one. Or if you can get the old one out, some machine shops can straighten it, weld up the damaged place and turn it back to diameter, though the cost may be higher than making one starting with new steel.
Gerald J.
