New Holland 273 baler
Gumby
12-26-2006 07:07:39
I've come across a New Holland 273 baler, twine tie, that I'm about to buy. Any comments on the good and/or bad points about this model? What years were they built?
The baler has sat outside unprotected for about 5-6 years. There is modest surface rust, but the sheet metal is great. The knotters are rusted but look like they've had little wear; I've been using an old NH Super 68 baler for the last few years, so I've got some experience tinkering with the knotter mechanisms.
Thanks for any input.
seth_ia
12-26-2006 19:32:40
 Re: New Holland 273 baler in reply to Gumby, 12-26-2006 07:07:39
we've got a 273. It's a good low capacity baler. You will know when you over feed it because the right side(from the tractor seat) gets loose. I do less and less small bales all the time, but if I do replace the baler it will be with a Hesston. After buying a big square baler, an inline with a stuffer is the only way to go. However if you only do a few bales don't hesitate to go with a 273, they are a good baler. I am not a NH kotter expert, but I think older NH knotters are identical. They can out work one guy on the rack, but usually not two unless the guys on the rack our idiots.
Seth_ia
12-26-2006 19:17:43
Do you have the name and contact info on the company that made the stroke counter?
Iowa Jim
12-26-2006 20:37:35
 Re: New Holland 273 baler in reply to Seth_ia, 12-26-2006 19:17:43
The Stroke Counter I have is from a company in Klamath Falls, Oregon, but they are out of business now I believe.
There is a company advertising in the Progressive Hay Farmer that has stroke counter. They are called Lehman Brothers in Amity, Oregon. Might give them a shout about their units.
Jim
Iowa Jim
12-26-2006 08:26:10
We have a NH 273 that bales between 8,000 and 12,000 bales each year. It is a tough machine for its age and capacity. The three big drawbacks for our operation are the smaller capacity (70 strokes per minute), older style chamber charger, and the narrower pick-up width compared to new machines.
We have added the following to our baler to help improve our baling:
Lights - Added one light shining into the pickup, one light shining forward from over the pickup, two lights shining back to help with stacking.
Moisture Tester - A Farmex in-chamber moisture tester to monitor the moisture as we bale.
Stroke Counter - We added a stroke counter to better regulate the number of strokes per bale. This has helped our bale consistency quite a bit.
Preservative Applicator - We added a preservative applicator with a remote control rheostat for the use of either Propionic Acid based hay preservative or a blend of Organic Acid Salts, Antioxidants, and Microbes. We have "saved" several cuttings of hay by using a preservative.
We will be upgrading our baler in the near future. I don't know which baler yet, but it will be in the NH 570 class. We will look hard at the Hesston in-line balers, though.
Jim
RickL
12-26-2006 10:29:51
 Re: New Holland 273 baler in reply to Iowa Jim, 12-26-2006 08:26:10
Iowa Jim; I have a New Holland 570 if you want some info. Its on Hoelscher accumulator. Had Deere unit before
Cliff Neubauer
12-26-2006 10:01:52
Last year we went from NH 270 and 310 balers to a Hesston 4590 (we kept the 310 around for a backup since it's pretty rough) and we've had zero complaints with the Hesston. Loading on racks in good going we were putting 170 bales on each wagon and we would change wagons about every 30-35 minutes but it takes three good guys on the rack to keep up at that pace. It takes a little getting used to to driving with the inline baler but once you do it would be hard to go back to a side pull. What we really love about the inline is the bale consistancy, the only time you need to adjust the tension is when the moisture changes. In one field last summer on the better dirt we were tying bales every 12 strokes and on the lighter dirt it was 80+ strokes between bales but all the bales were the same and we never adjusted the tension, with our New Hollands we were constantly adjusting the tension in those conditions. The inline balers are a little harder to find, our's came from out in South Dakota but it was 10 years old with only 50,000 bales on it setup with hydrualic pickup lift and hydraulic tension just the way we wanted it.
Tom in TN
12-26-2006 08:11:56
Gumby,
I have a NH 273 Hayliner that I've had for about 8 years now. I frankly don't remember what year it was made, but I imagine it's about 30 years old. I bale at least two and usually three cuttings of grass hay on twenty acres every year. I usually have about 5 or 6 bales each year that fail to tie, but other than that, it works perfectly.
Since I'm not nearly as clever as most of the guys on this forum, I don't do any maintenance on the baler except that I grease it EVERY time I take it to the field. I leave the old hay in the chamber and the bale that is in the knotter mechanism at the end of each year. When those first two bales come out the next year, I just throw them away.
I have had tremendous success with my 273. I hope you do too.
Tom in TN
Kevin5456
12-26-2006 07:33:24
It depends on how they are wanting for it and how bad you want it. What will you be doing with your 68?
Kevin
