Massey 9 Square Baler
Kevin5456
12-21-2006 18:34:58
I need to know anything and everything about this baler. Years made, hp required, part availability, and how big of bales it puts out. How good is this baler? Kevin
MLD
01-11-2007 08:09:57
 Re: Massey 9 Square Baler in reply to Kevin5456, 12-21-2006 18:34:58
I own one, works good but needs a good thick steady windrow for good bales. If the hay is thin, the bales aren't tight.
JerryCPP(WA)
12-22-2006 17:57:00
I had a #12 and it ran fine off an 8N (20 HP on a good day.) I now have a #3, and it has a 16 HP Wisconsin. My point is, not much in the horsepower department is needed.
JJ. in B.C.
12-21-2006 21:24:40
Hi Kevin, good little baler for small acreage if not wore out !!, about 30 hp will handle it, puts out a 15x18 bale 30" or 38" long depending which sprocket you use, new and used parts readily available, number of parts from #3, #9, #10 are interchangable. Made in late 60s early 70s i believe. HTH . JJ.
