Manure spreader(-ing) problem
Chris in MO
12-20-2006 20:10:09
I've got a bunch of very well composted manure/bedding which I have been working on spreading in some thin areas where I intend to frost seed some orchard grass/red clover later this winter. When I say this is well composted, I mean it. It is a uniform black color and texture. You can't tell what it used to be at all and it has no manure odor at all.
This is wonderful stuff for the soil, and I've got a bunch of it. The problem is that it doesn't seem to spread very well. When the spreader is full, it spreads over a broad area. Once about a third of the load is spread, it only spreads directly behind the spreader, basically within the tire tracks. When it gets down to the last 40% of a load, it doesn't even hit the beaters, it just falls off the back. Ultimately this is because it is super fine textured.
I've tried speeding the chain up or slowing it down. I've also tried varying the ground speed of the tractor. The spreader is an old New Holland. I can't read the model number. About 4 foot wide and 8 foot long bed. The beaters do not adjust in any way.
Any suggestions? Right now, some areas get way too much and some areas get way too little. I'm not worried about the too little, I can solve that by just driving slower. It is spreading too thick in the last 40% of the load when it just drops off the back.
Thanks in advance.
Christopher
ErnieDD
12-21-2006 15:52:26
 Re: Manure spreader(-ing) problem in reply to Chris in MO, 12-20-2006 20:10:09
Try putting a bale of hay in the front of the spreader. This will push the load into the beaters. Keep a close eye on the location of the bale and be sure to stop before it reaches the beaters.
May not be such a great idea if the apron chain is worn/weak.
John e.c.MI
12-21-2006 09:42:50
Manufacturers used to make a "litter pan" that bolted on under the beaters to force finer material to be spread more evenly.
John e.c.MI
12-21-2006 09:42:03
Chris in MO
12-20-2006 20:43:39
I had not thought about harrowing. Good idea. I think I'll work up a hitch for the rear end of the spreader and drag it while spreading. Leave it in the field where I leave off and hitch up on the next trip.
BTW, would a thick mat of that smother grass or would the rain, etc. wash it down so the grass can get through? This question is sort of academic since where I'm spreading you can see an awful lot of ground between the grass even in the springtime.
Christopher
Brian in MO
12-21-2006 06:23:52
 Re: Manure spreader(-ing) problem in reply to Chris in MO, 12-20-2006 20:43:39
Chris I think that the first 1" rain you get would wash it around and spread it out so that you can't even tell where you have been at least if it's a dry and powder as most of mine is when I spread it. I usually clean out the horse lots in the summer when it is good and dry and you can put it on pretty thick but within a couple of weeks it blends in. Brian
kyhayman
12-20-2006 20:20:33
Mine does the same thing (in my case its because I' still working on the part of the pile that got put there in 1999). Usually its all evened out in 12 months or so. I usally just put it on like it falls. Might not work in your case.
I hae noticed that chain harrowing after does a nice job of evening it out.
