Cub snow plow on a Farmall 100?
BDM
12-18-2006 22:10:38
Will a Cub snow plow assembly fit a Farmall 100?(same as a Super A)
Hugh MacKay
12-19-2006 03:32:42
 Re: Cub snow plow on a Farmall 100? in reply to BDM, 12-18-2006 22:10:38
BDM: It's always been my understanding both blades use the model No. 60. I expect the mounting hardware for the Cub blade is a bit different from SA, 100, etc. Probably a bit of fabrication will make it work. Most of the Cub-SA implements were that way, just different mounting hardware. The only one that couldn't be modified to fit was the 22 sickle mower. Cub pto turned opposite direction from SA.
If your interested, I have a decent photo of SA type mounting for that blade. Send me an e mail, I'll return the photo, then you can compare.
BDM
12-19-2006 17:16:35
 Re: Cub snow plow on a Farmall 100? in reply to Hugh MacKay, 12-19-2006 03:32:42
Thanks Hugh. That would be much appreciated.
gtxxx1970(AT)comcast.net
Remove two of the "x" for "gtx". Trying to avoid SPAM.
Brian
