Jonfarmer
12-18-2006 19:45:00
Re: Hay bale management in reply to WA Gerry, 12-18-2006 17:36:29
Kickers work very good, just wagons are expensive and you still got to unload them. Your at quite a disadvantage with not being able to get used wagons in your area, but even around here, hay wagons pretty much never get any cheaper than $800 a piece, and thats for wooden rack ones thats not in the best of shape, and they go up from there, the all steel wagons are the most sought after since they don't need the constant maintenance that the wooden ones do, but they are 2-3 times the cost. I have a JD 14T baler, and the guy who commented about the 14T making smaller bales is false, it makes the same standard size bales the brand new ones do, but the big thing is the 14T was made back in the day when farms were much smaller and the tractors were not as powerful, so it is much lower capacity and therefor much slower going than a new baler. The reason I keep a 14T is because I only make a few hundred bales a year, so I can make do and can't justify upgrading. However, I have worked for area farmers who have nice New Holland balers with kickers, slap a powerful tractor on them and even with 3 people unloading the wagons, we can barely keep up with it. Doing a bunch of square bales by yourself is a heck of a job and there doesn't seem to be an easy way around hard work, unless you get hold of one of them automatic bale wagons, but the price of those is outlandish, so I haven't seen any other than the New Holland website, although, they also have a towed version of it to go behind a tractor, but I'll bet that even those would be way too expensive for your operation, but with these automatic bale wagons, you bale right on the ground, same as you have been, then this wagon has the ability to pick the bales up off the ground as you drive along and stacks them on the back of itself, then you can drive to where you want them and dump them in a very neat stack, pretty darn neat, but lots of $$$$ and thats why nobody has one around here.
