McCormick Disc plow NEED HELP!
Short Bolt
12-18-2006 08:14:09
I purchased a IH HM150 2 gang disc plow at a auction. Found out they sold the hitch in a scrap pile. Am converting it to a semi mount, but it pulls off to the land side bad and the tractor rear wheel is in the furrow but the 1 disc leaves a 13" strip from cut to furrow. Has any converted one of these? Dose any one have a owner manual for the plow? How do I find and line up the center of pull? The plow is in real good condition other wise. Thanks
Mingo
12-19-2006 05:50:27
 Re: McCormick Disc plow NEED HELP! in reply to Short Bolt, 12-18-2006 08:14:09
Sounds like you are cutting too much with the first disk. The right rear tractor wheel should be moved in as much as possible.
JMS/MN
12-18-2006 08:51:10
The line of draft for a moldboard plow is 1/4 the width of one bottom to the left of center of total cutting width of the plow. I imagine the concept would apply to a disc plow as well, but I've never had any experience with one.
