55 ABH tire size
Scott Griffith
12-16-2006 06:09:05
The manual reads, 5.90 x 15. Is this the correct tire size for this plow? What tire size am I supposed to have. The 5.90 x 15 seems small for the rims.
Scott
Bob Collins
12-16-2006 11:04:29
 Re: 55 ABH tire size in reply to Scott Griffith, 12-16-2006 06:09:05
In 1952 John Deere changed the wheel size from 16" to 15" presumably to correspond to the trend at that time to smaller wheels on automobiles. This made it easier for a farmer to order his plow without tires and be able to find used car tires and save a few dollars. Earlier versions of the 55 series plows used 21" tires when that was a more common auto tire size. The vertical portion of the plow axle is longer on these later plows to maintain transport clearance. To answer your question; 5.90x15 is the specified size for late 55 series furrow wheels and for 55A and 55B (clutch lift)land wheel. 55H (hydraulic )plows specified a 6.40x15 power implement tire for the land wheel.
Scottt Griffith
12-16-2006 11:32:42
 Re: 55 ABH tire size in reply to Bob Collins, 12-16-2006 11:04:29
What size 16 inch tire does a 55H take? 6.00-16?
Scott
Bob Collins
12-16-2006 11:36:41
 Re: 55 ABH tire size in reply to Scottt Griffith, 12-16-2006 11:32:42
5.50x16 rib implement is the specified size, but a 6.00x16 would work just as well.
Scott Griffith
12-16-2006 11:30:08
I figure my manual is a post 1952 manual. I had the old tire in the garage and it is a 16 inch. So I reckon I'll have to find some 16 inch tires and put on it.
Thanks,
Scott Griffith
jhill52
12-17-2006 07:31:26
 Re: 55 ABH tire size in reply to Scott Griffith, 12-16-2006 11:30:08
Ifd you want to be realistic a worn out snow tire ofe a Chevy pickup would be period correct. Thats what most of them had . LOL
55 50
12-16-2006 07:18:57
I have a 44H and it has 16 inch rims on the furrow and land wheels. Seems like all that vintage of plows would use the same tire size. Possibly it is a misprint in your manual. Measure the rim and see what you need.
