What is the best tool for cutting hey?
Michael Price
12-14-2006 21:26:49
I was wondering what is the best implement to cut hay with?
burnetma
12-18-2006 22:39:37
 Re: What is the best tool for cutting hey? in reply to Michael Price, 12-14-2006 21:26:49
Yet another reason there is no perfect tool.
For heavy downed hay...New Idea Cut/Ditioner. Slow, but effective at getting the crop off the ground and cut.
jswintx
12-17-2006 20:35:52
Micheal, what kind of grass are you cutting? That alone really determines what kind of equipment you would be looking for. Also what kind of tractor are you running? Kuhn cutters are good but they weigh quite a bit more than a sickle and take more hp to run as well. I have some equipment I not useing if your interested. Send me an e-mail, [email protected], hope this helps.
Michael Price
12-15-2006 15:42:31
The reason I ask is within the next year or 2 I would like to get a baler to bale hey. I have a 7' sickle bar but was wondering what the best thing to cut it with would be so I could sell or trade some stuff I dont need or trade up to whatever the best tool would be. I would need to get it down the road so I dont need anything to big.
old
12-15-2006 10:13:53
In my book the #1 would be a disc mower/conditioner, #2 a MOCO like a NH 460 etc. #3 a sickle mower. All have there good points and bad points and the first on the list is also the one that will cost the most to buy new or used. The last is the cheapest and is more common then the others for a low price
Gerald J.
12-15-2006 08:43:57
A mower/conditioner, whether disc or sickle with conitioning rolls, will cut a couple days off your drying time and produce hay with both stem and leaf. Alfalfa dried without conditioning (or crimping) the stems tends to loose much more of the leaves and nearly all the quality food is in the leaves.
Gerald J.
low budget
12-15-2006 07:08:58
A cows teeth. ( grazing- anything else is second best)
Hay DR
12-15-2006 06:08:45
CUTTERS
-Single action sickle bar mowers Old technology of post Civil War days-Used is the way to go here with the lowend being a Ford 501 and the highend being a NH 451- $200- $2,000 used Double action sickle bar mowers: Increased capacity over a single action mower with increased maintenance. $2,400- $3,500 NEW European MFG- also special models for compact tractors -3 Point Drum Mowers The drum mower mows just like the well known disc mower. Small 2 drum mowers are available for 20 HP and up. Drum mowers will mow any crop in any conditions, they will not clog up. They are the most durable of the hay cutters. Some model need no exterior hydraulics. Popular brands: CCM, PZ, ZTR, Galfre', Deutz, Fella, & Star- CCM and Star make drum mowers for compact tractors prices start from $2,200 and up -3 point Disc mowers Sizes range from 5.5'- 13' If you are using a 60 HP tractor or smaller then usually 9' and below are the safe options for you. Some shaft drive MFG's have disc mowers for 30-40 HP tractors Brands: New Holland, New Idea, John Deere, Vermeer/Lely, Gehl, Vicon, Krone, Kuhn, Fort, Morra, Marangon, Zeigler, Fella, Hesston, JF, Bellon, G&S These mowers range from $3,800 to $10,000
When you talk new 3 point disc mowers there are really 3 choices.
There is basically two systems of disc mowers: shaft drive and oil bath gear drive. Much of the disc mower technology started in Europe so many USA brands are rebranded European MFG's disc mowers. Most all the disc mowers will mow hay, it's the dealer service, parts availability and repair down time that differentiates the mowers.
1. Established US marketing labels:
John Deere and Frontier- Both made by Kuhn in France. Oil bath design- The JD is the newer heavier cutterbar but is almost too heavy for smaller tractors. The Frontier is the GMD series that is lighter and will work well on the 40-70 Hp 2 wd utility size tractors.These mowers are made in the Czech Republic not France. New Holland- 2 series- 600 series, shaft driven, very heavy, made in the USA, HM200 series- Made by Sitrex in Italy, Comer oil bath design similar to the older Kuhn GMD design, sold as NH economy series- good on utility tractors AGCO- Hesston, New Idea, Massey- 1 Shaft driven series- Cutterbar design by AGCO but made by Comer, frame made in the USA. Good balance and weight for smaller utility tractors to larger cap tractors 2- Northern European Premium MFG that were the first to develop the disc mower technology.
Kuhn- 2 series - Oil bath design- The GMD500,600,etc is the newer heavier cutterbar but is almost too heavy for smaller tractors. The GMD-55,66,etc. series that is lighter and will work well on the 40-70 Hp 2 wd utility size tractors. Vermeer-LELY- Shaft drive- transmissions made in Europe and frame made in the USA. Good balance and weight for smaller utility tractors to larger cap tractors. Krone- Heavy duty oil bath design- made in Germany- smaller dealer network Vicon- Oil bath design- made in Holland- use distributors in the USA so their pricing is expensive- once the strongest selling in the 1980's but now a lesser sold brand Class- oil bath design- small US dealer network
3-Knock offs coming from all over the world- some much better than others- usually sold buy jockey dealers
Fort/Morra- oil bath cutterbar- made in Italy- copy of Kuhn HD cutterbar- some hitch problems but a good mower- small dealer network Maragon- Comer oil bath cutterbar from Italy- expensive for older technology- small dealer network Fella- Northern European company with a shaft design series made in Germany (heavy for small Tractors), and a oil bath cutterbar made in Italy. One distributor in the USA Sitrex, Tonutti, etc- Italian MFG's using a Comer cutterbar- older technology- usually sold buy jockey dealers
You notice I did not include Haymax because we have parts and components from around the world and make the frames in Tennessee and assemble here in the USA. Our Design is a modified Lely-Vermeer design. We have an advantage over them because we can produce the same technology as them at thousands $$$ less.
RickB
12-15-2006 03:11:10
 how do you cut hey? in reply to Michael Price, 12-14-2006 21:26:49
There is no one "right" answer. Operations and budgets differ. More detail about yous would help narrow the choices. Unless you are just trying to start a color war/size/technology arguement.
Hugh MacKay
12-15-2006 02:46:49
Michael: I think MSM and Pete are a bit out of your league, power wise. Didn't I see you discussing an 8' disk and what seemed like a suitable tractor. Your best bet is 7' sickle mower or haybine.
sd pete
12-15-2006 02:38:05
New Holland self propelled disk cutter
MSM
12-15-2006 01:07:32
A discbine, if you have enough ground to justify it and deep enough pockets to afford it, and a big enough tractor to run it
