Spring for Ground driven Manure Spreader
Rexalot
12-12-2006 06:05:27
Anybody know a good source for manure spreader parts? I need to find replacement springs for the ratchet mechanism on a ground driven spreader.
paul
12-12-2006 21:30:46
 Re: Spring for Ground driven Manure Spreader in reply to Rexalot, 12-12-2006 06:05:27
Well, you would go to the dealer the spreader came from for OEM parts. You haven't told us what brand it is, so no one can help with that.
Dad finished the day with some stout rubber bands on ours one day decades ago.
Hardware stores have bins of springs if you need an expanding spring. Easy to find, and exact specs are not important for this job.
Compression springs are a little tougher, but should find them at a better hardware store.
--->Paul
Delbert
12-12-2006 17:13:27
Try your local farm supply store sounds like a common spring might be worth a try. Do you have part of the old spring to show and tell?
kartking 22
12-12-2006 16:27:45
Forgot to let you know that there is also a site to post wanted items on Atis.net for free. (Antique tractor internet service) Click on the classified ads link and either search for what you are looking for or submit your own ad. It's free and I have used it and found parts for my David Bradley spreader. Might be worth a try.
kartking 22
12-12-2006 16:15:43
What brand of spreader is it? I have a few contacts for a some brands. JD, David Bradley, and Mineapolis Moline. Also, which model would be some help to find the exact spring. Looking for used or new?
IaGary
12-12-2006 14:23:42
Check out McMaster Carr they carry all kindsof springs and so on.
Gary
old
12-12-2006 07:45:33
Depending on the spring I have gotten a good number of them at auto parts stores. These are made to be cut and fitted as needed
Rexalot
12-12-2006 11:05:39
 Re: Spring for Ground driven Manure Spreader in reply to old, 12-12-2006 07:45:33
I"m wanting the spring that connects to the ratchet pawl on the right side of a spreader.
Using another spreader for comparison, it would appear that I need a spring about 10 inches long, 3/4"-1" in diameter. The material making the spring appears to be about 1/32" or 1/16" thick.
I looked at shoupparts, but all I see available is apron chains etc.
old
12-12-2006 12:22:38
 Re: Spring for Ground driven Manure Spreader in reply to Rexalot, 12-12-2006 11:05:39
Sounds a lot like a clutch return spring that you can buy at say and O'reillys auto parts store. They sell a pack of springs with 4 or 6 of them in the pack and you then just cut/bend the one end as needed to make it fit. I almost always keep a pack around for things that need a spring replaced
NEsota
12-12-2006 06:34:30
If it is an old Deere, I might be a source. Mail is open.
Rexalot
12-13-2006 04:52:45
 Re: Spring for Ground driven Manure Spreader in reply to NEsota, 12-12-2006 06:34:30
I may need help identifying the old beast...
I'll try to get a picture put up later this week.
Thanks for all the help and suggestions.
