Adjusting new plow coulters
toolz
12-11-2006 20:43:02
Just replaced the coulters on my IH #16 plow. Old ones were wore to 14", new ones are 17". I plan on plowing 7-8". How deep should the coulters cut? Or, how far up should they be from the bottom of the shares? Thanks for your help.
toolz
12-12-2006 21:56:06
 Re: Adjusting new plow coulters in reply to toolz, 12-11-2006 20:43:02
Thanks for the tips- I"ll get on it this weekend.
msb
12-11-2006 21:51:53
Set them just deep enough to cut the trash.Much deeper and they tend to push the trash and not cut it.Set them so they are cutting 1 inch or more(wider) than the moldboard if you are using coverboards to get a good flow of soil over the coverboard.1/2" if no coverboards.Set the midpoint(axle) of the coulter 2 inches ahead of the share point.More than 2inches ahead & up to 4 inches ahead in heavy trash for better trash flow.Even with the share point if the soil is very hard and or dry, or the coulter will try to lift the bottom out of the ground.
