potato digger for rocks in field
castor
12-10-2006 16:40:05
will a potato digger work to remove rocks from a plowed and disked field? I have the rockiest ground where i plant my food plot and you can't take a step without stepping on a rock. If they'll work, what kind should I look for? Thanks. doug.
Lloyd Llama
12-13-2006 05:46:50
 Re: potato digger for rocks in field in reply to castor, 12-10-2006 16:40:05
Give up! This is potato country - they've been using diggers & later harvesters here for years. Haul off truck loads of rocks every year. Next year there's another huge pile. My theory -rocks reproduce & grow underground!
phillip d
12-12-2006 17:18:49
hi castor,they use em around here,just a digger bed that lets the clay fall through the chains and the rocks and sticks ride up the bed and falls into a large box built on the end.They have a cylinder that opens up the bottom to let the rocks fall out when it fills up once you are ready to dump it,works really well.some even use a pto driven rock rake first to windrow the stuff before they use the picker,saves alot of time if you have acces to the stuff.phill
