JD #5 Sickle Mower
Michael D.
12-09-2006 22:39:47
What would be the value of a JD #5 sickle bar mower? It has been stored out side but maintained. I saw it used this last summer so I know it works. Thanks for you help!
Mike
James Howell
12-11-2006 07:57:01
 Re: JD #5 Sickle Mower in reply to Michael D., 12-09-2006 22:39:47
I have bought two #5 mowers within the last two months.
Paid $100 for a parts mower. I needed the yoke for my working #5 mower. It had a quick tach hitch that I also wanted. The cylinder was missing, gearbox lid was missing, otherwise a complete mower.
Paid $175 for another complete mower which will be reworked. I bought a new tire and tube. Will replace the knife and pitman. It has a foot lever. A foot lever recently sold on eBay for about $65. It has the "kick stand" and the front of the frame and another "kick stand" between the caster wheel and the yoke.
Last week a #5 mower sold on eBay for $455. It came with a parts mower. A few months back someone was giving one away on Yesterdays Tractors.
Since you know the mower works, you might want a minimum of $150 - $200.
If it is an "old" mower (late 1930's to 1940's) with hand lift lever and no cylinder, attached to "L" shaped mower bracket and no quick tach hitch, a minimum of $200.
If it is a "newer" mower (late 1940's to 1950's)with the lift cylinder and quick tach hitch, a minimum of $250. The working cylinder is the additional value.
Other "parts" that are still on the mower such as the two "kick stands", telescoping shaft guard, foot lever, mower to tractor brace/support, and complete original drive shaft will add to its value.
The knife, sections, and pitman can be bought at Tractor Supply. Carlisle manufactures the 4.00 X 9 caster wheel tire and tube.
I really enjoy using my #5 cycle mower. Good for mowing under trees, over terraces, and close to fences.
Hope this helps.
Chuck730DSE
12-10-2006 15:53:57
Around $150 dollar would be tops. It could need a few things so figure that in to your price. The seals typically leak and they are a bear to replace. They are very good mowers when set up properly.
Hayfarmer
12-10-2006 09:59:22
It would depend upon condition, apparently working but sometimes things work in spite of the maintenance Some parts are still available and there are a lot in salvage yards to rob from. I have one I paid $125 for years ago and have used a lot. I traded a 3 point Ford mower for a JD#8 in good shape and a #5 that had been botched up to use on a 3 point hitch. I sold the #5 as botched as it was for $200. Hard to tell value, mainly what it is worth to you and the current owner.
michael price
12-10-2006 09:30:34
I just got a JD #8 sickle bar, well thats what Im told it is. Its in pretty good shape and I payed $50 for it and I think I got a good deal. I would think at least 100 bucks if it works good.
