SCV Doubler???
Joe in IN
12-07-2006 19:47:04
A couple years ago I ran across a 'thing' that plugs into the 2 outlets in the 1 SCV that a single SCV tractor has. It had a toggle switch and basically gave you another set of outlets so you could have 2 sets of hydraulics attached. Down side was you had to flip the toggle switch to get the correct one to work.
Anybody know where to get one of these. I am thinking this would be cheaper thanbuying all the parts for a second SCV.
Bob Semrau
12-11-2006 09:56:54
 Re: SCV Doubler??? in reply to Joe in IN, 12-07-2006 19:47:04
My old JD 510 baler had one on it that toggled which outlets were live with every pull of a rope. There are lots of scrap JD 510 round balers !
RickL
12-09-2006 02:38:32
Joe in IN. You can also get them in a button style that lets you put it right on the hyd lever you using and when you hold the button it it activates the other cylinder othwerwise it is same as usual,no switch lever back and fourth then moving hyd lever works much much nicer for loaders. Iuse mine on 4440 to make it be the 3rd outlet for running small bale grapple.
michael price
12-08-2006 20:55:04
All of these ive seen were about $500 but if you dont want to spend the money on the electric one Ive seen cheaper ones with a lever you turn. I cant remember what these were but I think around 50 bucks.
Joe in IN
12-08-2006 21:55:53
 Re: SCV Doubler??? in reply to michael price, 12-08-2006 20:55:04
Boy if you can remember who sells them that would be great.
I have no problems manually moving the lever. Only need one when I start and when I stop. Other wise it is the second one getting all theuse.
paul
12-08-2006 23:58:01
 Re: SCV Doubler??? in reply to Joe in IN, 12-08-2006 21:55:53
I've seen them at tsc for about $100, need 2.
Northern hyd, Prince, Baum, Surplus Center would be the other places to search.
--->Paul
RlH
12-08-2006 15:57:34
What tractor are you putting it on I put an extra outlet on 20 serries JD cheaper it workes great
Joe in IN
12-08-2006 16:19:48
 Re: SCV Doubler??? in reply to RlH, 12-08-2006 15:57:34
JD3010D
I'm seeing close to 500 bucks for these contraptions... Howmuch is a second remote??
Rick Kr
12-08-2006 12:36:13
My land pride rear blade had one so I could run two cylinders on one set of remotes.
the blade already comes with the pad welded on it.
At first I thought it was kind of goofy, but once I started using it, it was great.
Just hooked a rod to it so I could flip it from the seat of the tractor.
Rick
Bob
12-07-2006 20:00:31
Around my area, at least, some of the tractor dealers, as well as TSC carry them.
Link
http://www.fasse.com/
IaGary
12-07-2006 19:59:18
www.shoupparts.com
Gary
