modifying a disc
glennster
12-05-2006 14:27:38
i recently rebuilt a 14ft kewannee disc. the disc misses about 6" or so down the center between the gangs. it kinda drives me nuts. so i was thinking, maybe mount a coulter off a plow, or i have a few vibra shanks off a field cultivator, maybe put a sweep in the center behind the first gang, or i also have a few anhydrous knives laying around. i'm sure alan in neb would have somethin handy, any thoughts?
RickL
12-06-2006 05:36:23
 Re: modifying a disc in reply to glennster, 12-05-2006 14:27:38
should been one on there when it was original. The shank is basic same as on chisel plows thoough. One from field cultivator may not be heavy enough,but it fine to give it a try.
michael price
12-05-2006 19:42:02
Ive seen alot of disks with a cultivator and about a 6" sweep on it stuck in the center. I just bought a 8' kewanee disk that im planning on fixing up and was planning on doing the same.
Allan In NE
12-05-2006 15:28:52
Yes,
Strap on that cultivator shank and a 6" duckfoot.
That's supposed to be there from the factory anyway. :>)
Allan
glennster
12-05-2006 18:40:13
 Re: modifying a disc in reply to Allan In NE, 12-05-2006 15:28:52
thanks alan, i fuggured if any body knew how to modify it, you would! that will give me a weekend project. course the ground here is froze solid and we got about 10" of snow so i wont be able to test er out yet, unless..... .i got a propane tank for the grain dryer....maybe i could rig some kind of a torch to mount in front of the disc..... ....nah....better wait for warm weather!!!!! thanks again! glenn
jhill52
12-05-2006 14:35:34
Some IH discs used to have a field cultivater in the back between the disc gangs.
Jerry
