restoreing old plow
Harry Zappe
12-04-2006 20:23:42
I have a old rusted plow and clear some of the r rustoff moldboard and found these numbers NCP14/ GP214 share/7127 patened may 4th 1915 could any one give me the make of the plow? Also,the size of the plow and where I might get more information Thankyou-Harry Zappe
Bob Collins
12-05-2006 12:59:58
 Re: restoreing old plow in reply to Harry Zappe, 12-04-2006 20:23:42
I'm not where I can look up anything right now, but I believe your plow is a John Deere. I think if you look again the number may really be NGP214... and it is likely a 14". If you can find a number on the beam, you may find John Deere stamped there also but possibly not. The numbers you have listed are parts of the bottom assembly and could be used on many plows. Numbers, description or a picture would be helpful.
paul
12-04-2006 20:37:38
How many bottoms?
What size is the bottom(s)? Measure straight across, perpendicular to the direction of travel, not at the angle of the bottom.)
Steel wheels? Trip lift?
Color? (Yea, 'rust' is common but if you find any other shades..... ;)
Someone will probably pick it up from the numbers you posted, I'm not that smart. :)
--->Paul
