Skid steer mounted bale wrapper
Kent in NB
11-30-2006 06:21:07
Anyone have any experience with the Ag Wrap bale wrapper? Mounts to your skid steer, or your 3-pth. Made in East Canton,Ohio, by Ag Nation Products. Saw it in the most recent FARM SHOW magazine. Looks like a slick rig. Thanks ,Kent in NB.
Formerly PaMike
12-02-2006 03:38:40
 Re: Skid steer mounted bale wrapper in reply to Kent in NB, 11-30-2006 06:21:07
I have one, so I will answer your questions the best I can. BIG, BIG, HEAVY TRACTOR
I use my wrapper on an Oliver 1755(85 HP) The tractor has a very heavy loader on it and a heavy cab. This tractor is marginal at best. I should really add some front end weights, but I havent figured out how since the loader is in the way. My buddy tried using his 1256(100+) hp and any time he tried to move the tractor with a bale on the back the front end of the tractor came off the ground. With a full stack of weights on the front it was OK, but not great. I would recommend calling Ag Nation. I called them one time and talked to a guy that actually uses it, and makes it. He had all kinds of tips. I really, really doubt the skidloader mount will work well unless you have a HUGE skidloader. The wrapper itself probably weighs close to 1000 lbs, then you figure there is about a foot of dead space between the mounting plate and where the bale starts. So combine all the weight and the leverage from the bale being way out in front and I think it will tip most any skidloader on its nose. You need a tight tense bale. My old NH 852 just doesnt work well with it. I trip the bales early so they arent as big. The bales then just arent dense enough. They want to squash down in between the rolls, then the bale will not turn. They was very aggrivating to me as I battled it many times. I think a GOOD 4 x 4 baler would solve this problem. The guy at ag nation did admit that you really need to wrap them right as they come out of the baler so that they dont develope a flat spot. That flat spot will wedge between the rolls and make the bale hard to turn. I think with smaller bales this is more critical because the rolls are gripping more on the sides, allowing the bale to slip down, where as on bigger bales the rolls are more underneath the bale.
Another problem was that when you turn the speed down on the wrapper with the needle valve you create a pressure drop. The pressure is now less at the hydraulic motors so when I had heavy bales on it the wrapper would stall. I turned the speed up and that solved the problem, but then the wrapped went that fast that the plastic came off the roll very quickly and didnt prestretch properly. What I needed to do was turn the flow down on my tractor remotes, but at the time they were rusted in place.
I think with a BIG tractor, a tight bale, and wrapping right away it would do an ok job. I have only used mine for one season so I really didnt get to work the bugs out yet. I would think for the $9000 price tag you could buy a used belt wrapper that would do a better job. I will brag a little now. I got mine used from the IH dealer. It was repoed from someone, and was missing a roll. Paid $1200 for it, and spend $70 in material and about 10 hours labor to get it operational so I really cant complain too much about it. Any questions?
Kent in NB
12-04-2006 18:36:08
 Re: Skid steer mounted bale wrapper in reply to Formerly PaMike, 12-02-2006 03:38:40
Hi Mike. Thanks for the reply. I e-mailed Ag Nation and they are going to mail a DVD showing how this machine works. If it comes , I will post a review.
kyhayman
11-30-2006 06:31:30
I looked at them really hard. Personally, I think they would do a great job putting a weatherproof leayer on hay, I dont think they would do squat to make ferminted hay. Even well wrapped individually or in a tube, it takes such tiny holes or defects to allow air into the hay. Those open ends butted together are a gallery for rain water, and cant possibly be air tight.
RodInNS
12-01-2006 07:38:02
 Re: Skid steer mounted bale wrapper in reply to kyhayman, 11-30-2006 06:31:30
David,
Are you sure you're talking about the same machine. The one I saw pictured in FarmShow this month didn't leave anything open. It appears to use that same technology as the Claas baler/wrapper combo. The bale is rotated on rollers, but there is no table spinning. The plastic rotates around the bale. I thought that was a fairly acceptable way of wrapping a bale. I don't know any more about that particular machine other than what I read about it, but it looked to be fairly well built....
Rod
kyhayman
12-01-2006 09:24:30
 Re: Skid steer mounted bale wrapper in reply to RodInNS, 12-01-2006 07:38:02
I looked up the one in farm show, it is different than the other 3 pt and skid steer units I have seen. The only ones I had seen and referred to in my earlier posts just wrap the sides, and leave the ends open.
The $9300 sticker on this one gives me pause. I hope they have a booth at the National Farm Machinery Show in Feb. Thats about half what a new inline is, and Im probably done with inlines as thats what ate me back in Oct.
kyhayman
12-01-2006 06:23:02
If you decide to get one, please let us know how it does. I'd love to use something besides this monster inline I've been using. I've not seen one at any of the university wrapped silage field days, they all said when asked (I was asking) that spoilage was unacceptable.
Kent in NB
12-01-2006 05:23:37
Depends on your situation. Many people are able to make alot of good silage this way. I was just wondering if this particular machine was well built, and if it works.
