John Deere 224WS Baler with Wisconsin Engine
Gimpl
11-28-2006 21:28:58
I picked up this baler and am now trying to get it running.
My first order of business is to get the Wisconsin going. Does anyone know if these are 6 or 12 volt starters and if they are pos or neg ground. Also looking for any tips you might have with this type of a setup.
I am also looking for an owners manual that will tell me how to operate the machine. Need to figure out how to load the wire into it since it was out when I bought it.
Thanks much for the help.
Glen in TX
11-29-2006 22:48:01
 Re: John Deere 224WS Baler with Wisconsin Engine in reply to Gimpl, 11-28-2006 21:28:58
Probably 6V positive ground unless it's been changed? JD Publications 800-522-7448
Dave Sherburne NY
11-29-2006 15:11:59
Use AC not Champion plugs Had one once it would
start once with Champions and not again changed to AC it would start all summer long.
Bob Bedlan
11-29-2006 09:21:04
I have a operator's manual for John Deere Wisconsin model VF4 engine for operation on
John Deere No. 116W hay baler. It's pretty detailed on how to run and fix the motor.
gimpl
11-29-2006 19:45:27
 Re: John Deere 224WS Baler with Wisconsin Engine in reply to Bob Bedlan, 11-29-2006 09:21:04
Hi Bob,
Does you book tell you if it is 6 or 12 volts?
Tx Jim
11-29-2006 03:38:19
There should be a decal on rear close to wire box to show how to thread wire. If you can't find decal I'll lead you through threading if you need before op. manual arrives. I think the starter is 12V. Those Wisconsin engines can be very trying at times. Betcha it has a stuck valve!!! Tx Jim
old
11-28-2006 21:50:18
You should be able to get a manual from a JD dealer. I got one for a 14T last year and the cost wasn't all that bad, some where around $30 or so.
