You gotta match your harvest equipment, can fudge a couple inches at most, less if you have 6 or more row corn head. Can you find a 20 inch combine head in your area? Those are a little rare. A horse is 42 inches wide, so that is how wide the first planters were. Fit the team down the rows. Corn can give you max yield if each plant is equally spaced & gets as much sun & root room as possible. So perhaps planting each plant 6 inches from the next in all directions would be 'best' for max yield. But no one's figured out a good way to harvest that yet. So, from horse days, we've gone to 42, 40, 38, 36, 30, 22, 20, & 15 inch row spacing for corn. MOST common was 38-40 inch (wide row) and now almost everyone is at 30 inch spacing narrow row). The last 5-10 years, you see some 15 inch rows, but that takes a special corn head. In beet areas, planters are set to 20 or 22 inches, & you see some few corn heads that size. In general, today, you will find 38 inch or 30 inch as the most common & easiest to find someone to harvest your corn. 38 inch pickers are pretty cheap, and corn heads are more common in 30 inch these days. 20 inch _might_ work with a 1-row corn picker. I would figure out how to harvest the crop, before setting up the planter. 30 inch is going to be the most common in most areas. --->Paul
