Haybine parts
Eugene SWIA
11-22-2006 03:54:16
Check your post on NH 461 parts. Gene
NHBalerman
11-22-2006 20:55:56
 Re: Haybine parts in reply to Eugene SWIA, 11-22-2006 03:54:16
Thanks for the reply,mostly what I need is the two cables,but I would like to have the spring,the cover around the spring and the adjustment rod that screws into the spring and also the handle that adjust the tension on the spring.When I got this one it had been sitting outside and the cables had been broken and I don't know the exact length to make them and I have tried to make some and a clamp want hold the pressure and tried splicing the cable together and can't seem to get the cable to hold,so I thought if I could find the good used cables then I could have them made that would work. Let me know what you want to sell and how much. Thanks
Eugene SWIA
11-23-2006 07:56:57
 Re: Haybine parts in reply to NHBalerman, 11-22-2006 20:55:56
Give me a call 712 563 4115. Got the bolts soaking in skunk oil. The tube is rusted and is integeral w/the head. It can be cut out,which will make getting the spring out simpler. Don't have a adjustment handle,but I made one for the 460 I used to use. I drive a grain hopper out of Manning IA,Dending on where you live I can deliver, Maybe. Gene
NHBalerman
11-23-2006 19:04:02
 Re: Haybine parts in reply to Eugene SWIA, 11-23-2006 07:56:57
Thanks, I live in Carthage,Tx. Hwy 59 comes through town. Maybe you go to Houston,Tx some,hwy 59 and hwy 79 cross here in town.
Eugene SWIA
11-22-2006 03:57:37
Should have been addressed to NH Balerman.
