New round baler comparison
Brad M
11-17-2006 18:55:01
I am looking to upgrade round balers before next season, just wondering pros and cons of some. I currently run a 435 JD with bale kicker and net wrap. I am leaning toward a Vermeer 604M, but have never seen one ran. What are your thoughts on the JD 468, NH BR750/ CIH RBX463, and the Vermeer 604M. I mostly bale coastal and sudan. Thanks
Cliff Neubauer
11-18-2006 07:06:26
 Re: New round baler comparison in reply to Brad M, 11-17-2006 18:55:01
For what it's worth we've had a couple of red guys around here go from the Case IH/New Holland round balers to Deere's and they couldn't be happier. They say the Deere's will bale tough hay much better than the red balers.
Allan In NE
11-18-2006 07:12:23
 Re: New round baler comparison in reply to Cliff Neubauer, 11-18-2006 07:06:26
Just bought some straw that the fellow had used a JD 535? on.
Very impressed with the bales. Too darned big fer my little operation tho.
Allan
Cliff Neubauer
11-18-2006 09:59:58
 Re: New round baler comparison in reply to Allan In NE, 11-18-2006 07:12:23
Most bales around here are the 5x6' size. I like that size for handling and feeding but if you want to haul them very far on a truck they are too wide to haul without oversize permits.
signman
11-18-2006 04:39:09
I just purchased my second 605M. Between the baler and the dealer I couldn't be happier. We bale half alfalfa hay and cornstalks. This is a machine that was built for the toughest stalks and just happens it will still bale hay. The new netwrap system is fantastic and simple. I baled 555 bales last week in less than 12 hours baling time. Those are 605 bales. I can't imagine how many you could do an hour with a 604. Good choice here. Also, in 26 years of running Vermeer we have never waited for a part. But that is our dealers we have had. Can't say that for our local deere dealer.
Tx Jim
11-18-2006 03:01:28
Brad,I have a JD 467 mega-wide pick-up that I like better than any baler I've owned. All the others I owned were JD's. NH's seem to be good but one doesn't see any Vermeer's around here. Tx Jim
KEH
11-18-2006 16:29:13
 Re: New round baler comparison in reply to Tx Jim, 11-18-2006 03:01:28
The last time I was at a farm show where the coastal hay was properly dry the John Deeres made the tightest bales. Present day balers all seem to do a good job.I would consider which brand had the closest best dealer support.
435 JD is a good baler. Improvement on the new balers will be marginal over the 435 IMO.
I assume you are going to a 4 ft wide baler so you can transport them on the road easier.
I have used Vermeers and found them to be well made. New Hollands seem to be made a little lighter.
Vermeers use cheaper flat belts instead of those expensive diamond tread belts on the JDs. Of course, I have never worn out a belt either on my small operation.
KEH
