Ford loader installation
screamingholllow
11-16-2006 08:02:40
I bought a nice used Ford industrial front end loader (with front pump) for my Ford 4000 tractor, from a nearby discount equipment dealer. They sell, they don't do work or install. It came off a Ford 5000, which is basically the same frame tractor, but a few inches longer between the front bracket mount and rear axle. The plates that bolt to the axle look plenty long enough to accomodate a three inch shorter frame. Any tricks I should know for how to get this hooked up?
I figure I'll put the bucket against a tree and winch the frame up so i can drive the tractor into the frame and then lower the frame enough to fit under the rear axle. Is there a better way?
