Massey Harris No. 26 Adjustable Plow - Hyd. Lift
Ken from Ontari
11-15-2006 18:48:42
Looking for the dimensions of the hyd. cyl.
used on subject plow, ie. Cyl barrel length and
diameter, Length of cylinder rod when plow is in
transport mode?
Thanks
Leroy
11-19-2006 06:40:38
 Re: Massey Harris No. 26 Adjustable Plow - Hyd. in reply to Ken from Ontario, 11-15-2006 18:48:42
Diameter will depend mor on your tractor than anything, a 2 bottom with the pressure of a 2 cylinder John Deere B should work with a 2" cylinder but a tractor with a lower pressure system may need a 2 1/2" for a two bottom and I am thinking that plow carries the trail (furrow) wheel so would only be avaible as a 2 bottom, Now a 28 plow has the furrow fheel that carries the rear of the plow and would be made in 2-3-4 bottom sizes and would the larger the plow take a larger cylinder. On the 28 3-12" we had behind a 50 AR John Deere we used the 2 1/2" John Deere B tractor cylinder with no problems, same size cylinder on other 2 & 3 bottom plows.
msb
11-16-2006 18:12:22
I would think it would take a standard 8 inch stroke.A three to three & a half inch bore should suffice on a model 26 unless it has more than 3 bottoms,but I can't remember when Farm Equipment Manufacturers Assn. standardized cylinders, three point sizes , etc.
