PTO U-joint cross bearing installation (Part 2)
Paul Schultz
11-15-2006 03:17:25
I now have the old cross bearing off my unique old Ford PTO shaft. The unique implement end yoke is ready to apply to the new PTO shaft but now I need advise on how to properly install the new cross bearing.
I assume I disassemble the cross bearing by removing the end caps (without dislodging the needle bearings!). After carefully placing the cross bearing into position do I just use a hammer to strike the cross bearing end caps into the yokes and onto the cross bearing? Won't I send needle bearings flying across the garage!?
I want to do this right so I'll wait for some experienced advise.
Thanks to all for some great suggestions on removal of the old cross bearing!
Paul.
ET
11-15-2006 07:14:19
 Re: PTO U-joint cross bearing installation (Part 2 in reply to Paul Schultz, 11-15-2006 03:17:25
Put a dab of grease in the bearing caps when you have them off. It will help hold the needles in place, leave the grease fitting out untill the cross is assembled. That will vent the excess grease. When the u-joint is all back togeather rap the backside of the yoke with a hammer this will usually center up the cross and relieve any stiffness in the joint.
Iagary
11-15-2006 03:56:56
Now is where the press or big vise is used.
Put one cap in the yoke and press it in part way as far as you can and still get the cross in.
Put the cross in it and start the other cap.
When close enough together for the cross to reach the second cap slide the cross over so it is started in both caps to help hold the pins in place.
Now tighten the caps as far as you can then grab those sockets that old was talking about and finish settin the caps untill you can get the snap rings in.
Gary
IBorange in TX
11-15-2006 14:24:59
 Re: PTO U-joint cross bearing installation (Part 2 in reply to Iagary, 11-15-2006 03:56:56
I agree w/Iagary, but let me add this. When you have both caps started, put the capped end in the vise and apply pressure to both caps at the same time. After the caps are pressed in the yoke, then take the socket and tap the cap enuf to get the lock ring in the grove for both caps. Have fun..... ..
RodInNS
11-15-2006 05:30:49
Gary,
I couldn't have said that better myself. That's exactly how I install them, right or wrong. Good description.
Rod
Paul Schultz
11-15-2006 16:11:19
 Re: PTO U-joint cross bearing installation (Part 2 in reply to RodInNS, 11-15-2006 05:30:49
Thanks to all,
I'll give Gary's method a go either later tonight or tomorrow morning. I'll report back on my progress!
Paul.
